下面的代码用vc写的,我想转成keil
2285|4
 楼主| chuandaoxy 发表于 2008-11-18 20:29 | 显示全部楼层 |阅读模式
struct ID
            uint8_t manufacturer;       /**< Manufacturer id                           **/
            uint8_t device[2];          /**< Device id                                 **/
            uint8_t extendedInfoLength; /**< Extended device information string length **/
void ATD45DB161D::ReadManufacturerAndDeviceID(struct ATD45DB161D::ID *id)
    DF_CS_inactive;    /* Make sure to toggle CS signal in order */
    DF_CS_active;      /* to reset Dataflash command decoder     */
    /* Send status read command */
    spi_transfer(AT45DB161D_READ_MANUFACTURER_AND_DEVICE_ID);
    /* Manufacturer ID */
    id->manufacturer = spi_transfer(0xff);
    /* Device ID (part 1) */
    id->device[0] = spi_transfer(0xff);
    /* Device ID (part 2) */
    id->device[1] = spi_transfer(0xff);
    /* Extended Device Information String Length */
    id->extendedInfoLength = spi_transfer(0xff);
->这个符号好像keil不实,这是为什末呢
原野之狼 发表于 2008-11-18 20:37 | 显示全部楼层
老兄,这是C++代码
你的KEIL支持么?
hotpower 发表于 2008-11-18 20:44 | 显示全部楼层
->是支持的,::恐怕是KEIL ARM才行~~~
香如故 发表于 2008-11-18 20:50 | 显示全部楼层
c也支持->啊
结构指针
常来21ic 发表于 2008-11-19 09:31 | 显示全部楼层
重新写
逻辑很简单嘛,为何不重新写!
