时序报告的不明白之处
2330|4
 楼主| sxtz531 发表于 2013-1-22 20:22 | 显示全部楼层 |阅读模式
      最近在学习约束的一些东西,有些不明白的地方,想请教各位:
      写的简单的串并转换代码:
     module shift #(parameter DATIN_WIDTH = 16,
               parameter DATO_WIDTH  = 16)
                  input  clk,
                  input  rst_,
                  input  ld,
                  input [DATIN_WIDTH-1:0] data_in,
                  input  shift_in,
                  input  shift_en,
                  output shift_out,
                  output reg [DATO_WIDTH-1:0] data_out);
                  always @(posedge clk or negedge rst_)
                  begin
                          if(!rst_)
                                 data_out<= 'b0;
                         else if(ld)
                               data_out <= data_in;
                        else if(shift_en)
                               data_out<= {data_out[DATO_WIDTH-2:0],shift_in};
                  end
                  assign shift_out = data_out[DATO_WIDTH-1];
      endmodule
     在synplify9.6.2中的作了简单约束,其中.sdc文件所作的约束内容:
          define_input_delay -disable      -default -improve 0.00 -route 0.00
          define_output_delay -disable     -default -improve 0.00 -route 0.00
          define_input_delay               {rst_}  1.00 -improve 0.00 -route 0.00
          define_input_delay               {ld}  1.00 -improve 0.00 -route 0.00
          define_input_delay               {data_in[15:0]}  1.00 -improve 0.00 -route 0.00
          define_input_delay               {shift_in}  1.00 -improve 0.00 -route 0.00
          define_input_delay               {shift_en}  1.00 -improve 0.00 -route 0.00
          define_output_delay              {shift_out}  2.00 -improve 0.00 -route 0.00
          define_output_delay              {data_out[15:0]}  2.00 -improve 0.00 -route 0.00
          时钟在 implementation options 中约束在100MHz。
    最后在时序分析报告察看:
        Input Ports:
              Port             Starting            User           Arrival     Required
             Name            Reference       Constraint     Time        Time         Slack
                                   Clock
       data_in[0]      System (rising)     1.000          1.000       11.671       10.671
       data_in[1]      System (rising)     1.000          1.000       11.671       10.671
           ld              System (rising)     1.000          1.000       10.310       9.310
          rst_            System (rising)     1.000          NA          NA           NA
        shift_en        System (rising)     1.000          1.000       10.694       9.694
         shift_in        System (rising)     1.000          1.000       11.671       10.671
       Output Ports:
                                     Clock
         data_out[0]      shift|clk (rising)     2.000          6.961       8.000        1.039
         data_out[1]      shift|clk (rising)     2.000          6.961       8.000        1.039
        data_out[15]     shift|clk (rising)     2.000          6.961       8.000        1.039
           shift_out        shift|clk (rising)     2.000          6.961       8.000        1.039
请问,代码中只有一个时钟clk,为什么会在输入的里面时钟那一项是system,而且后面详细的报告也有:
           Detailed Report for Clock: shift|clk
           Detailed Report for Clock: System
两个报告。这两个报告有什么关系,这个system该如何理解?
GoldSunMonkey 发表于 2013-1-22 22:20 | 显示全部楼层
他认识那个是系统时钟。
 楼主| sxtz531 发表于 2013-1-23 21:45 | 显示全部楼层
他认识那个是系统时钟。
谢谢版主,可以说的详细些吗?system是系统时钟,那和代码中的clk是一个什么关系?input管脚的使用system分析的,output是以clk分析的,这两者又有什么不同?
GoldSunMonkey 发表于 2013-1-23 22:46 | 显示全部楼层
综合工具,而且是synplify的,我实在不知道他机制
 楼主| sxtz531 发表于 2013-1-24 21:01 | 显示全部楼层
谢谢版主!
