新手求助:麻烦各位帮我看看是怎么回事情
2884|4
 楼主| liokok119 发表于 2009-4-10 12:10 | 显示全部楼层 |阅读模式
今天小弟写了一个抢答器程序 程序如下:
    org 0000h
    ljmp mian
    org 0003h
    ljmp ttq;抢答时间调节
    org 0013h
    ljmp ttd;答题时间调节
    org 000bh
    ljmp timerq;抢答剩余时间
    org 001bh
    ljmp timerd; 答题剩余时间
    org 0040h
mian:    mov 30h,#30;抢答剩余时间
    mov 31h,#60;答题剩余时间
    mov 32h,#0 ;抢答时间结束
    mov 33h,#0 ;答题时间结束
    mov 33h,#0 ;抢答时间暂存
    mov 36h,#0 ;答题时间暂存
    mov 35h,#71h ;选手号
    mov 37h,#0 ;选手号暂存
    mov 38h,#30;抢答时间调整暂存
    mov 40h,#60;答题时间调整暂存
lop:    mov sp,#60h
    mov ie,#8fh
    mov ip,#0
    mov tmod,#22h
    mov th0,#06h
    mov tl0,#06h
    mov th1,#06h
    mov tl1,#06h
    mov p1,35h
loop:    jb p3.0,jp  ; 检查抢答是否开始
    mov p1,#0
dis:    lcall display
    jnb p3.1,fw
k1:    jnb p1.0,k11    ;检查错误抢答
k2:    jnb p0.1,k22
k3:    jnb p0.2,k33
k4:    jnb p0.3,k44
k5:    jnb p0.4,k55
k6:    jnb p0.5,k66
k7:    jnb p0.6,k77
k8:    jnb p0.7,k88
    ljmp loop
k11:    lcall dly    ;违规抢答检查
    jb p0.0,k2
    mov 35h,#1
    ljmp dis
k22:    lcall dly
    jb p0.1,k3
    mov 35h,#2
    ljmp dis
k33:    lcall dly
    jb p0.2,k4
    mov 35h,#3
    ljmp dis
k44:    lcall dly
    jb p0.3,k5
    mov 35h,#4
    ljmp dis
k55:    lcall dly
    jb p0.4,k6
    mov 35h,#5
    ljmp dis
k66:    lcall dly
    jb p0.5,k7
    mov 35h,#6
    ljmp dis
k77:    lcall dly
    jb p0.6,k8
    mov 35h,#7
    ljmp dis
k88:    lcall dly
    jb p0.7,loop
    mov 35h,#8
    ljmp dis
fw:    lcall dly    ;结束
    jnb p3.1,loop
    ljmp dis
jp:    lcall dly    ;正常抢答检查
    jb p3.0,loop
    setb tr0
loop1:    mov a,p0
    anl a,#0ffh
    cpl a
    mov 37h,a
    mov r1,a
display2:
    jnb p3.1,jsh1;回答完毕主持人结束
    mov r1,30h
    cjne r1,#0,dtjs1;抢答时间到自动结束
    mov dptr,#tab
    mov a,30h
    mov b,#10
    div ab
    movc a,@a+dptr
    mov p1,a
    mov p2,#02h
    lcall dly
    mov p1,#0ffh
    mov a,b
    movc a,@a+dptr
    mov p1,a
    mov p2,#01h
    mov p1,#0ffh
    lcall dly
    mov p1,#71h
    mov p2,#04h
    lcall dly
    mov p1,#0ffh
jp1:
    cjne r1,#01h,jp2
    mov 35h,#1
    ljmp display1
jp2:    cjne  r1,#02h,jp3
    mov 35h,#2
    ljmp display1
jp3:    cjne r1,#04h,jp4
    mov 35h,#3
    ljmp  display1
jp4:    cjne r1,#08h,jp5
    mov 35h,#4
    ljmp display1
jp5:    cjne r1,#10h,jp6
    mov 35h,#5
    ljmp display1
jp6:    cjne r1,#20h,jp7
    mov 35h,#6
    ljmp display1
jp7:    cjne r1,#40h,jp8
    mov 35h,#7
    ljmp display1
jp8:    cjne r1,#80h,loop1
    mov 35h,#8
display1:
    jnb p3.1,jsh;回答完毕主持人结束
    mov r2,36h
    cjne r2,#0,dtjs;答题时间到自动结束
    clr tr0
    setb tr1
    mov dptr,#tab
    mov a,36h
    mov b,#10
    div ab
    movc a,@a+dptr
    mov p1,a
    mov p2,#02h
    lcall dly
    mov p1,#0ffh
    mov a,b
    mov p1,a
    mov p2,#01h
    lcall dly
    mov p1,#0ffh
    mov a,35h
    mov p2,#04h
    lcall dly
    mov p1,#0ffh
    ljmp loop1
jsh:    lcall dly
    jnb p3.1,display1
    clr tr1
    mov 36h,40h
dtjs:    mov 30h,39h
    ljmp lop
jsh1:    lcall dly
    jnb p3.1,display2
dtjs1:    mov 30h,40h
    ljmp lop
timerq:    dec 38h
    mov 30h,33h
    reti
timerd:    dec 40h
    mov 31h,40h
    reti
ttq:    clr tr1
    clr tr0
    clr ex0
lop1:    jnb p3.0,dd
lop11:    jnb p3.1,jj
lop12:    jnb p3.2,wc
    ajmp lop1
dd:    lcall dly
    jb p3.0,lop11
    inc 38h
    mov r3,38h
    cjne r3,#99,lop1
    mov 38h,#0
    ajmp lop1
jj:    lcall dly
    jb p3.1,lop12
    dec 38h
    mov r3,38h
    cjne r3,#0,lop1
    mov 38h,#99
    ajmp lop1
wc:    lcall dly
    jb p3.2,lop1
    setb ex0
    reti
ttd:    clr tr1
    clr tr0
    clr ex1
lop2:    jnb p3.0,dd1
lop21:    jnb p3.1,jj1
lop22:    jnb p3.3,wc1
    ajmp lop2
dd1:    lcall dly
    jb p3.0,lop21
    inc 40h
    mov r4,40h
    cjne r4,#99,lop2
    mov 40h,#0
    ajmp lop1
jj1:    lcall dly
    jb p3.1,lop22
    dec 40h
    mov r4,40h
    cjne r4,#0,lop2
    mov 40h,#99
    ajmp lop2
wc1:    lcall dly
    jb p3.3,lop2
    setb ex1
    reti
dly:    mov r7,#100
dly1:    mov r6,#30
    djnz r6,$
    djnz r7,dly1
    ret
display: mov  dptr,#tab
    mov a,35h
    movc a,@a+dptr
    mov p1,#0
    mov p2,#01h
    lcall dly
    mov p1,#0ffh
    mov p1,#0
    mov p2,#02h
    lcall dly
    mov p1,#0ffh
    mov p1,a
    mov p2,#04h
    lcall dly
    mov p1,#0ffh
    ret
tab:
end
这段程序里面 有下列错误提示为:
1.asm(31): error A51: TARGET OUT OF RANGE
k88:    lcall dly
    jb p0.7,loop
还有其他错误 请哥哥些帮我看看是怎回事情谢谢
lyjian 发表于 2009-4-10 13:29 | 显示全部楼层
跳转地址超出-128/+127范围了
 楼主| liokok119 发表于 2009-4-10 14:00 | 显示全部楼层
2楼: 跳转地址超出-128/+127范围了
哦 谢谢
bjc125 发表于 2009-4-10 20:12 | 显示全部楼层
....建议楼主的程序有条理点 最好使程序模块化 结构化
 楼主| liokok119 发表于 2009-4-12 22:15 | 显示全部楼层
bjc125
谢谢 这位哥哥  我以后会注意
