STM32F207 时钟配置
6951|2
 楼主| pentral0311 发表于 2013-1-28 15:16 | 显示全部楼层 |阅读模式
STM32F207 时钟配置 问题
我配置的时钟文件如下,外部晶振是8M
void RCC_Configuration(void)
  ErrorStatus       HSEStartUpStatus;
  RCC_ClocksTypeDef RCC_ClocksStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(ENABLE);
/*000b Zero wait state, if 0 < SYSCLK≤ 24 MHz
      001b One wait state, if 24 MHz < SYSCLK ≤ 48 MHz
      010b Two wait states, if 48 MHz < SYSCLK ≤ 72 MHz*/
    /* Flash 1 wait state */
    FLASH_SetLatency(FLASH_Latency_1);
    /* DISABLE PLL */
    RCC_PLLCmd(DISABLE);
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK1 = HCLK / 4 */
    RCC_PCLK1Config(RCC_HCLK_Div4);
    /* PCLK2 = HCLK / 2 */
    RCC_PCLK2Config(RCC_HCLK_Div2);
// /* ADCCLK = PCLK2 / 4 */
// RCC_ADCCLKConfig(RCC_PCLK2_Div4);
/*这里是我下载了官方F2系列 时钟配置文件 ,参考此文件做的 RCC_PLLSource_HSE = 8M*/
/* PLLCLK = (RCC_PLLSource_HSE/8) * 192/2 = 96 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE,8,192,2,8);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
/* Get Clock */
RCC_GetClocksFreq(&RCC_ClocksStatus);
// /* unused GPIO pins set to analog-input mode to improve EMC */
// GPIO_AIM_Init(1);
//   SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);//使用与系统同样的
// SysTick_SetReload(0xffffff);     //以最大开始重新装载
而我实际得到的是300M,附件里面有我读到的时钟值 不知道是哪里出错,望指点一二!!!
JasonWangFAE 发表于 2013-1-28 15:23 | 显示全部楼层
you need to modify "HSE_Value" this value from 25000000 to 8000000 in the stm32f20x.h file.
评分
参与人数 1威望 +3 收起 理由
pentral0311 + 3 很给力!
查看全部评分
 楼主| pentral0311 发表于 2013-1-29 14:20 | 显示全部楼层
收到,3Q!!!
