哪位大哥能写红外发射程序?
1835|2
 楼主| 星空互联 发表于 2013-1-29 21:36 | 显示全部楼层 |阅读模式
现有90C516RD+单片机一枚,可以当8051对待,红外发射管接P3^3,欲模拟DVD遥控器,发射用户码0x00,用户反码0xff,操作码0x0d,操作反码0xf2,NEC格式编码,谁会啊,小仙困苦好久了,没办法了
yanyinzhong 发表于 2013-1-30 09:09 | 显示全部楼层
首先你要能够产生38kHz波形输出(在IO上),然后就很简单了
refee 发表于 2013-3-13 13:47 | 显示全部楼层
楼主是想要这个咚咚么 :lol
#ifdef SUPPORT_IRCODE_OUTPUT
#define IRCODE_GPIO 4 //GAME_LAT Pin8 GPIO4
extern const BYTE ir_mapcode[];
static BYTE get_ircode(BYTE IrFunc)
    BYTE i;
    for (i = 0; i < 96; i++)
        if (ir_mapcode[i] == IrFunc)
            break;
    return i;
static void delay_necir_clk(BYTE Clk560uS)
    UINT16 delay10us = Clk560uS * 56 + 1;
    while (delay10us --)
        delay_1us(10);
#if 1   //Refee 072112
static void send_necir_byte(BYTE data)
    int i ;
    for (i = 0; i < 8; i ++)
        GPIO_O_SET(IRCODE_GPIO, 0);
        delay_necir_clk(1);
        GPIO_O_SET(IRCODE_GPIO, 1);
        if (data & 0x01)
            delay_necir_clk(3);
        else
            delay_necir_clk(1);
        data >>= 1;
void send_necir_flame_data(BYTE IrFunc)
    BYTE IRcode = 0;
    GPIO_F_SET(IRCODE_GPIO, 1);
    GPIO_M_SET(IRCODE_GPIO, 1);
    GPIO_E_SET(IRCODE_GPIO, 1);
    //Lead code
    delay_necir_clk(16);
    delay_necir_clk(8);
    //Custom code
    send_necir_byte(0x00);
    send_necir_byte(0xFF);
    //Data code
    IRcode = get_ircode(IrFunc);
    send_necir_byte(IRcode);
    IRcode = 0xFF - IRcode;
    delay_necir_clk(9);
#else
enum
    SEND_IR_IDLE = 0,
    SEND_IR_START,
    SEND_IR_LEADCODE,
    SEND_IR_CUSTOMCODE,
    SEND_IR_DATACODE,
    SEND_IR_FINISH,
#define IRBit0 2 // 01
#define IRBit1 4 // 0111
BYTE SendBitCount = 0;
BYTE SendIR_ClkCount = 0;
BYTE Send_NEC_IR_State = SEND_IR_IDLE;
BYTE CustomCode[16] =  //0x00FF
    IRBit0, IRBit0, IRBit0, IRBit0, IRBit0, IRBit0, IRBit0, IRBit0,
    IRBit1, IRBit1, IRBit1, IRBit1, IRBit1, IRBit1, IRBit1, IRBit1
BYTE DataCode[16] =  //0x00FF
static void polling_send_ir(void)
    switch (Send_NEC_IR_State)
        case SEND_IR_START:
            SendIR_ClkCount = 24; // 560us*24 = 13.5ms
            Send_NEC_IR_State = SEND_IR_LEADCODE;
            break;
        case SEND_IR_LEADCODE:
            SendIR_ClkCount --;
            if (SendIR_ClkCount)
                if (SendIR_ClkCount > 8) // L 9ms H 4.5ms
                else
            else
                SendBitCount = 16;
                SendIR_ClkCount = CustomCode[0];
                Send_NEC_IR_State = SEND_IR_CUSTOMCODE;
            break;
        case SEND_IR_CUSTOMCODE:
            SendIR_ClkCount --;
            else
                SendBitCount --;
                if (SendBitCount)
                    SendIR_ClkCount = CustomCode[(16 - SendBitCount)];
                else
                    SendBitCount = 16;
                    SendIR_ClkCount = DataCode[0];
                    Send_NEC_IR_State = SEND_IR_DATACODE;
            break;
        case SEND_IR_DATACODE:
            SendIR_ClkCount --;
            else
                SendBitCount --;
                if (SendBitCount)
                    SendIR_ClkCount = DataCode[(16 - SendBitCount)];
                else
                    SendIR_ClkCount = 9; // 560us*9 = 5ms
                    Send_NEC_IR_State = SEND_IR_FINISH;
            break;
        case SEND_IR_FINISH:
            SendIR_ClkCount --;
            else
            break;
        default:
            break;
    int i = 0;
    UINT16 IRcode = 0;
    IRcode = ((0xFF - get_ircode(IrFunc)) << 8) | get_ircode(IrFunc);
    for (i = 0; i < 16; i ++)
        if (IRcode & 0x01)
            DataCode[i] = IRBit1;
        else
            DataCode[i] = IRBit0;
        IRcode >>= 1;
    Send_NEC_IR_State = SEND_IR_START;
    while (Send_NEC_IR_State)
        polling_send_ir();
        delay_necir_clk(1);
#endif
#endif
