错误已标出1处,高手能看出这个“整形”错误,大家看看吧
5515|1
 楼主| tingtang 发表于 2009-5-2 20:53 | 显示全部楼层 |阅读模式
直接看最后几行,msp430.做adc温度传感,一共1处,谢谢
#include <msp430x14x.h>
#include "cry1602.h"
#include "math.h"
#define   Num_of_Results  32
typedef unsigned char uchar;
typedef unsigned int uint;
uchar shuzi[]={"0123456789."};
uchar tishi[]={"temp:"};
static uint results[Num_of_Results];
void Trans_val(uint Hex_Val);
/****************主函数******************/
void main(void)
WDTCTL=WDTPW+WDTHOLD;                     //关闭看门狗
_EINT();
LPM0;
/****************中断服务函数*********************
用途;多次平均计算P60口的模拟电压数值************/
#pragma vector=ADC_VECTOR
__interrupt void ADC12ISR(void)
static uint index=0;
results[index++]=ADC12MEM0;        //移动结果
if(index==Num_of_Results)
uchar i;
unsigned long sum=0;
index=0;
for(i=0;i<Num_of_Results;i++)
sum+=results;
sum>>=5;                          //除以32
Trans_val(sum);
/*********************转换数据函数****************
功能;将16进制转换数据变换成三位10进制真实的模拟电压数据*****/
void Trans_val(uint Hex_val)
unsigned long caltmp;
uchar d[4];
float c,i,r;
uint curr_volt;
//uchar i,r,n,p;
caltmp=Hex_val;
caltmp=(caltmp<<5)+Hex_val;            //caltmp=Hex_val*33
caltmp=(caltmp<<3)+(caltmp<<1);        //caltmp=caltmp*10
curr_volt=caltmp>>12;                  //curr_volt= caltmp/2^n
r=(1700/(851-curr_volt))-1.4;
c=(1/((1/298.15)-(log(r)/3950)))-273.15;
 c=c/10;//得到c为4位有效数字  小数点前、后各两位
d[0]=(int)(c);
   c-=d[0];
   c*=10;
   d[1]=(int)c;
   c-=d[1];
   c*=10;
   d[2]=(int)(c);
   c-=d[3];
   c*=10;
   d[3]=(int)(c);
   for(i=0;i<=4;i++)*******错误提示Error[Pe031]: expression must have integral type
  DisplChar((6+i),1,shuzi[d]);
ayb_ice 发表于 2009-5-2 20:56 | 显示全部楼层
i是浮点数,不能用++
