| 在对sd卡初始化的时候,复位成功,但是收不到00. 我吧接收到的数据用串口输出,如下:
 红线划的部分是复位之后保持不变的部分,后面的每次复位会有变化。
 部分代码:
  case(sdinit_cstate)
  SDINIT_RST: begin
   if(delay_done) sdinit_nstate <= SDINIT_CLK; //上电后40us延时完成,进入74+CLK状态
   else sdinit_nstate <= SDINIT_RST; //等待上电后40us延时完成
  end
  SDINIT_CLK: begin
   if(cmd_rdy) sdinit_nstate <= SDINIT_CMD0; //74+CLK完成
   else sdinit_nstate <= SDINIT_CLK;
  end
  SDINIT_CMD0: begin
   if(cmd_rdy && (spi_rx_dbr == 8'h01)) sdinit_nstate <= SDINIT_CMD55;
   else sdinit_nstate <= SDINIT_CMD0;
  end
  SDINIT_CMD55: begin
   if(cmd_rdy && (spi_rx_dbr == 8'h01)) sdinit_nstate <= SDINIT_ACMD41;
   else sdinit_nstate <= SDINIT_CMD55;
  end
  SDINIT_ACMD41: begin
   if(retry_rep == 8'hff) sdinit_nstate <= SDINIT_CMD55; ///////////响应超时,返回IDLE重新发起命令
   else if(cmd_rdy && spi_rx_dbr == 8'h01) sdinit_nstate <= SDINIT_CMD55;
   else if(cmd_rdy && spi_rx_dbr == 8'h00) sdinit_nstate <= SDINIT_CMD16;
   else sdinit_nstate <= SDINIT_ACMD41;
  end
 /* SDINIT_CMD1: begin
   if(cmd_rdy) sdinit_nstate <= SDINIT_CMD16;
   else sdinit_nstate <= SDINIT_CMD1;
  end*/
  SDINIT_CMD16: begin
   if(cmd_rdy && (spi_rx_dbr == 8'h00)) sdinit_nstate <= SD_IDLE;
   else sdinit_nstate <= SDINIT_CMD16;
  end
  SD_IDLE: sdinit_nstate <= SD_RD_PT;
  SD_RD_PT: begin
   if(cmd_rdy) sdinit_nstate <= SD_RD_BPB;
   else sdinit_nstate <= SD_RD_PT;
  end
  SD_RD_BPB: begin
   if(cmd_rdy && arg == arg_r+P_MEM-32'h0000_0200) sdinit_nstate <= SD_DELAY;
   else sdinit_nstate <= SD_RD_BPB;
  end
  SD_DELAY: begin
   if(done_5s) sdinit_nstate <= SD_IDLE; //显示下一幅图片
   else sdinit_nstate <= SD_DELAY;
  end
 default: sdinit_nstate <= SDINIT_RST;
 endcase
