SDIO操作SD卡SD_WriteBlock()出错
3448|1
 楼主| inurl 发表于 2013-2-18 18:48 | 显示全部楼层 |阅读模式
  错误代码是errorstatus = SD_CMD_RSP_TIMEOUT                 = (3), /* Command response timeout */
  错误位置是:
/* Set the block size, both on controller and card */
  if ((BlockSize > 0) && (BlockSize <= 2048) && ((BlockSize & (BlockSize - 1)) == 0))
    power = convert_from_bytes_to_power_of_two(BlockSize);
    SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) BlockSize;
    SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SET_BLOCKLEN;
    SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;
    SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;
    SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;
    SDIO_SendCommand(&SDIO_CmdInitStructure);
    errorstatus = CmdResp1Error(SDIO_SET_BLOCKLEN);
    if (errorstatus != SD_OK)
      return(errorstatus);
airwill 发表于 2013-2-19 12:45 | 显示全部楼层
TIMEOUT 想必是工作被延迟了
