C6455连接问题
2093|1
beiwaroad|  楼主 | 2013-2-21 10:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, rc, TE, ST, ce
出错报告:
Error connecting to the target:
Error 0x80000244/-1202
Fatal Error during: Register, Initialization, OCS,
CPU continually indicated it was 'not ready'
This is considered a catastrophic event, user can either force CPU ready
and continue the debug process by choosing button 'YES', or abort current
by reset the system
Sequence ID: 0
Error Code: -1202
Error Class: 0x80000244
Board Name: C6455 XDS560 Emulator
Cpu Name: C6400PLUS_0
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
Error 0x00000020/-2011
Error during: Execution,
An internal error occurred in which an illegal action (0x00000006) was requested while disconnected.
Sequence ID: 6
Error Code: -2011
求教dsp的复位信号时间能不能过长,1.2v内核电压纹波值200mv算不算大?就是连不上仿真器,不知道是什么问题
