请问有谁调试成功过CY8C21434 SPIM 模块的读操作
1082|1
 楼主| justbybing 发表于 2013-2-23 13:58 | 显示全部楼层 |阅读模式
我可以向SPI从设备写操作,但是死活都不能进行读操作,请高手指点
 楼主| justbybing 发表于 2013-2-23 13:59 | 显示全部楼层
void SPI_Write(unsigned char dig)
        PRT2DR |= CS;
        while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_TX_BUFFER_EMPTY)){};
        PRT2DR &= ~CS;                         // set slave select low
        SPIM_1_SendTxData(dig); // set message to transmit
        while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_SPI_COMPLETE)){};
        PRT2DR |= CS;                        //
unsigned char SPI_Read(void)
        unsigned char ReceivedData;
        PRT2DR |= CS;
        PRT2DR &= ~CS;
        SPIM_1_SendTxData(0x00);  // 写伪数据,以便读到数据
        while(!(SPIM_1_bReadStatus() &  SPIM_1_SPIM_RX_BUFFER_FULL));//RX Buffer register has received current data
        ReceivedData = SPIM_1_bReadRxData();
        PRT2DR |= CS;
        return ReceivedData;
