我用KEIL 运行汇编程序时,老是报错,错误如下: ALL_dly.asm(11): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(12): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(13): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(14): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(15): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(16): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(18): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL ALL_dly.asm(259): error A45: UNDEFINED SYMBOL (PASS-2) ALL_dly.asm(260): error A45: UNDEFINED SYMBOL (PASS-2) ALL_dly.asm(261): error A45: UNDEFINED SYMBOL (PASS-2) ALL_dly.asm(262): error A45: UNDEFINED SYMBOL (PASS-2) ALL_dly.asm(263): error A45: UNDEFINED SYMBOL (PASS-2) ALL_dly.asm(264): error A45: UNDEFINED SYMBOL (PASS-2) ALL_dly.asm(838): error A39: REGISTER OPERAND EXPECTED ALL_dly.asm(839): error A39: REGISTER OPERAND EXPECTED ALL_dly.asm(840): error A39: REGISTER OPERAND EXPECTED ALL_dly.asm(862): error A39: REGISTER OPERAND EXPECTED ALL_dly.asm(871): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION ALL_dly.asm(872): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION ALL_dly.asm(873): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION ALL_dly.asm(1036): error A39: REGISTER OPERAND EXPECTED ALL_dly.asm(1051): error A39: REGISTER OPERAND EXPECTED ALL_dly.asm(2152): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION ALL_dly.asm(2211): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION ALL_dly.asm(2222): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION ALL_dly.asm(2241): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION
程序是人家调试好了的.应该没有什么问题,我怀疑是我自己没有把KEIL设置好. 但是我怎么设置都不行,请大家帮帮忙. |
