再发一便,请各位帮看看我的8251程序哪里有问题
2406|0
 楼主| ccjchen 发表于 2007-2-4 14:45 | 显示全部楼层 |阅读模式
都快一个月了,还是一点反应都没有,用串口调试助手发送和接收都为空,其中T0用做8251对89C52的发送接收中断信号
#define _TEST_C_
#include "reg52.h"
#include "stdlib.h"
#include "absacc.h"
#include "intrins.h"
#include "test.h"
#define uchar unsigned char
#define uint  unsigned int
#define COM8251 XBYTE[0x8601]
#define DAT8251 XBYTE[0x8600]
uchar data_temp[10]={0xAA,10,22,32,0,0};
uchar i,s;
void  initmcu(void);
void main(void)
{   EA = 1;
    initmcu();
    COM8251 = 0x00;
    COM8251 = 0x00;
    COM8251 = 0x00;
    COM8251 = 0x4e;
    COM8251 = 0x37;
void  initmcu(void)
     TMOD = 0x06;     //9600波特11.0592MHz,方式2
     TL0  = 0XFF;    TH0 = 0XFF;
     TCON = 0x01;    IP  = 0x02; ET0 = 1;
void Trans8251()  interrupt 1 using 2
   for(;;)
     for(i=0;i<4;i++)
            do
                s = COM8251;
            }while((s&0x01)==0);
              DAT8251 =  data_temp;
     for(i=0;i<4;i++)
            do
                s = COM8251;
            }while((s&0x02) == 1);
        data_temp = DAT8251;
