VADSP++5 TS201链接出现问题,请高手!
2867|1
 楼主| 286172908 发表于 2013-3-11 11:44 | 显示全部楼层 |阅读模式
[Error li1021]  The following symbols referenced in processor 'P0' could not be resolved:
        '_ez_c2afft3_f [__ez_c2afft3_f]' referenced from '.\Release\prof.doj'
        '_ez_c2afft_f [__ez_c2afft_f]' referenced from '.\Release\prof.doj'
        '_ez_csmulcs_f [__ez_csmulcs_f]' referenced from '.\Release\prof.doj'
        '_ez_cvlogmag_f [__ez_cvlogmag_f]' referenced from '.\Release\prof.doj'
        '_ez_cvmagsqr_f [__ez_cvmagsqr_f]' referenced from '.\Release\prof.doj'
        '_ez_r4fftw1_f [__ez_r4fftw1_f]' referenced from '.\Release\prof.doj'
        '_ez_v10log_f [__ez_v10log_f]' referenced from '.\Release\prof.doj'
        '_ez_vadds_f [__ez_vadds_f]' referenced from '.\Release\prof.doj'
        '_ez_vaddv_f [__ez_vaddv_f]' referenced from '.\Release\TS6-4.doj'
        '_ez_vimovs_f [__ez_vimovs_f]' referenced from '.\Release\prof.doj'
        '_ez_vint2float3_f [__ez_vint2float3_f]' referenced from '.\Release\prof.doj'
        '_ez_vmaxmin_f [__ez_vmaxmin_f]' referenced from '.\Release\prof.doj'
        '_ez_vmuls3_f [__ez_vmuls3_f]' referenced from '.\Release\prof.doj'
        '_ez_vmuls_f [__ez_vmuls_f]' referenced from '.\Release\prof.doj'
        '_ez_vmulv3_f [__ez_vmulv3_f]' referenced from '.\Release\prof.doj'
        'angle_est2 [_angle_est2]' referenced from '.\Release\TS6-4.doj'
        'det_main [_det_main]' referenced from '.\Release\TS6-4.doj'
        'ez_vimov_f [_ez_vimov_f]' referenced from '.\Release\TS6-4.doj'
        'right_rngn_pd [_right_rngn_pd]' referenced from '.\Release\TS6-4.doj'
        'test_chnl_err [_test_chnl_err]' referenced from '.\Release\TS6-4.doj'
        'test_s_curve [_test_s_curve]' referenced from '.\Release\TS6-4.doj'
        'tgt_dbin [_tgt_dbin]' referenced from '.\Release\TS6-4.doj'
        'tgt_rbin [_tgt_rbin]' referenced from '.\Release\TS6-4.doj'
        'vel_in_p [_vel_in_p]' referenced from '.\Release\TS6-4.doj'
        'velocity_pd [_velocity_pd]' referenced from '.\Release\TS6-4.doj'
Linker finished with 1 error
cc3089: fatal error: Link failed
Tool failed with exit/exception code: 1.
Build was unsuccessful.
这是个什么问题?怎么解决啊?
zhangmangui 发表于 2013-3-11 13:47 | 显示全部楼层
好像与使用的P0有关系
