CCS中下载程序时,load错误
2646|1
 楼主| huangfeng33 发表于 2013-3-15 10:38 | 显示全部楼层 |阅读模式
CCS中下载程序时,load错误,屏幕下方出现Trouble Writing Memory Block at 0xac0 on Page 0 of Length 0xac0: Error 0x00000002/-1153 Error during: Memory,  The memory at 0x01BC0010 continually indicated it was 'not ready' All memory operations currently in progress were aborted in order to regain control of the processor. This is considered a catastrophic event, but the debugger should  still be able to access memory and CPU registers. System state has been altered.  It is strongly advised that the processor should be reset before resuming execution,   Sequence ID: 1 Error Code: -1153 Error Class: 0x00000002
怎么解决啊?
jlass 发表于 2013-3-15 17:15 | 显示全部楼层
好像是说设备没准备好,这种问题没有统一的答案,你自己多测测吧
