2402程序读写和编程器读出问题
2236|1
 楼主| mrainborn 发表于 2008-6-7 13:36 | 显示全部楼层 |阅读模式
2402读写函数
#include<reg52.h>
#define uchar unsigned char
#define uint  unsigned int
#define WriteDeviceAddress 0xa0
#define ReadDeviceAddress 0xa1
sbit WP=P1^5;
sbit SCL=P1^6;
sbit SDA=P1^7;
void DelayMs(uint number);
extern void Watchdog();//喂狗
void Start_2402()//启动2402
   SDA=1;SDA=1;
   SCL=1;SCL=1;//延迟
   SDA=0;SDA=0;//延迟
   SCL=0;SCL=0;
void Stop_2402()//关闭2402
   SCL=0;SCL=0;
   SDA=0;SDA=0;//延迟
   SCL=1;SCL=1;//延迟
   SDA=1;SDA=1;
bit TestACK()//测试ACK
  bit ErrorBit;
  SDA=1;SDA=1;//延迟
  SCL=1;SCL=1;//延迟
  ErrorBit=SDA;
  SCL=0;SCL=0;
  return(ErrorBit);
void NoACK()
   SDA=1;SDA=1;
   SDA=1;SDA=1;
   SCL=1;SCL=1;
   SCL=1;SCL=1;
   SCL=0;
void Write8Bit(uchar input)//写8bit
  uchar temp;
  for(temp=8;temp!=0;temp--)
     SDA=(bit)(input&0x80);
     SCL=1;SCL=1;//延迟
     SCL=0;SCL=0;//延迟
     input=input<<1;
void Write2402(uchar ch,uchar address)//写一个字节
   Start_2402();
   Write8Bit(WriteDeviceAddress);//写器件地址
   TestACK();
   Write8Bit(address);//写操作地址
   TestACK();
   Write8Bit(ch);
   TestACK();
   Stop_2402();
   DelayMs(10);
uchar Read8bit()//读8bit
  uchar temp;
  uchar rbyte=0;
     SCL=1;SCL=1;
     rbyte=rbyte<<1;
     rbyte=rbyte|((uchar)(SDA));
     SCL=0;
   return(rbyte);
uchar Read2402(uchar address)//读一个字节
  uchar ch;
  Start_2402();
  TestACK();
  Write8Bit(address);
  TestACK();
  Start_2402();
  Write8Bit(ReadDeviceAddress);//写操作地址
  TestACK();
  ch=Read8bit();//读数
  NoACK();
  Stop_2402();
  return (ch);
    uchar temp;
    for(;number!=0;number--)
        for(temp=224;temp!=0;temp--);
主函数中的调用部分
写操作
 if(!(VT100&&VT300&&VT500&&VT700&&VT900))
  if(VT100==0)//写入VT=100
    if(!UP)
     Write2402(VT,0x00);//写低字节
     DelayMs(20);
     Write2402(VT>>8,0x01);//右移写高字节
     DelayMs(20);
     DISPLAY_VT=100;
  if(VT300==0)//写入VT=300
    if(!UP)
     Write2402(VT,0x02);//写低字节
     DelayMs(20);
     Write2402(VT>>8,0x03);//右移写高字节
     DelayMs(20);
     DISPLAY_VT=300;
  if(VT500==0)//写入VT=500
    if(!UP)
     Write2402(VT,0x04);//写低字节
     DelayMs(20);
     Write2402(VT>>8,0x05);//右移写高字节
     DelayMs(20);
     DISPLAY_VT=500;
  if(VT700==0)
    if(!UP)
     Write2402(VT,0x06);//写低字节
     DelayMs(20);
     Write2402(VT>>8,0x07);//右移写高字节
     DelayMs(20);
     DISPLAY_VT=700;
  if(VT900==0)
   if(!UP)
    Write2402(VT,0x08);//写低字节
    DelayMs(20);
    Write2402(VT>>8,0x09);//右移写高字节
    DelayMs(20);
    DISPLAY_VT=900;
读操作
FLOW_1_LOW=Read2402(0x00);//读出低字节
 DelayMs(20);
 FLOW_1_HIGH=Read2402(0x01);//读出高字节
 DelayMs(20);
 FLOW_1=((FLOW_1_HIGH<<8)+FLOW_1_LOW);//读出VT=100
 FLOW_2_LOW=Read2402(0x02);//读出低字节
 DelayMs(20);
 FLOW_2_HIGH=Read2402(0x03);//读出高字节
 DelayMs(20);
 FLOW_2=((FLOW_2_HIGH<<8)+FLOW_2_LOW);//读出VT=300
 FLOW_3_LOW=Read2402(0x04);//读出低字节读出
 DelayMs(20);
 FLOW_3_HIGH=Read2402(0x05);//读出高字节
 DelayMs(20);
 FLOW_3=((FLOW_3_HIGH<<8)+FLOW_3_LOW);//VT=500
 FLOW_4_LOW=Read2402(0x06);//读出低字节
 DelayMs(20);
 FLOW_4_HIGH=Read2402(0x07);//读出高字节
 DelayMs(20);
 FLOW_4=((FLOW_4_HIGH<<8)+FLOW_4_LOW);//读出VT=700
 FLOW_5_LOW=Read2402(0x08);//读出低字节
 DelayMs(20);
 FLOW_5_HIGH=Read2402(0x09);//读出高字节
 DelayMs(20);
 FLOW_5=((FLOW_5_HIGH<<8)+FLOW_5_LOW);//读出VT=900
这时写和读的地址是从0X00--0X09的
用编程器读出来的时候也是从0X00开始的
但是在把地址改成0X6000--0X6009的时候,写到的位置还和地址为0X00时一样
后又把地址改成6000==6009,写的位置就不一样了时从70开始的
如下如图
有点不明白,望大虾们提示
dai_weis 发表于 2008-6-7 14:27 | 显示全部楼层
24C02最大寻址才多大?
你弄了个0X6XXX?而且你的地址才是个无符号字符类型,最大才0XFF
