图中的(I)JPdownload 是什么?什么作用?谢谢
2600|3
 楼主| 放只 发表于 2007-3-30 12:53 | 显示全部楼层 |阅读模式
看不清是JPdownload   还是IPdownload   在图最左上角
这个电路是用总线方式控制1602液晶显示屏,以AT89S52为核心
源程序
#i nclude<reg51.h>
#i nclude<stdio.h>
#i nclude<stdlib.h>
#i nclude<intrins.h>
#i nclude<absacc.h>
#define busy 0x80 file://用于检测LCD状态字中的Busy标识
#define RSaddr 0x1000
#define RWaddr 0x2000
#define CSaddr 0x0400
#define wc 0xcfff
#define wd 0xdfff
#define rc 0xefff
unsigned char code homepage[] = {"www.ispdown.com"};
unsigned char code email[] = {"ispdown@21cn.com"};
void delay5ms(void)
 unsigned int TempCyc = 5552;
 while(TempCyc--);
void delay400ms(void)
 unsigned char TempCycA = 5;
 unsigned int TempCycB;
 while(TempCycA--)
   TempCycB=7269;
   while(TempCycB--);
void waitLcd()
    char temp;
 bit flag=1;
 while(flag==1)
   temp=XBYTE[rc];
   if (temp>>7==0) flag=0;
   P1=temp;
 P1=0xff;
void WC_Lcd(bit isCheck,char c)
   if (isCheck==1) waitLcd();
   XBYTE[wc]=c;
void WD_Lcd(char c)
    waitLcd();
 XBYTE[wd]=c;
void LcdInit()
    delay5ms();
 delay5ms();
 delay5ms();
 WC_Lcd(0,0x38);
 delay5ms();
 WC_Lcd(0,0x38);
 delay5ms();
 WC_Lcd(0,0x38);
 delay5ms();
 WC_Lcd(1,0x38);
 WC_Lcd(1,0x08);
 WC_Lcd(1,0x01);
 WC_Lcd(1,0x06); // 显示光标移动设置
 WC_Lcd(1,0x0C); // 显示开及光标设置
void displayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
 Y &= 0x1;
 X &= 0xF;
 if (Y) X |= 0x40;
 X |= 0x80;
 WC_Lcd(0,X);
 WD_Lcd(DData);
void displayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
 unsigned char ListLength;
 ListLength = 0;
 Y &= 0x1;
 X &= 0xF;
 while (DData[ListLength]>0x20)
   if (X <= 0xF)
     displayOneChar(X, Y, DData[ListLength]);
  ListLength++;
  X++;
void main(void)
 delay400ms();
 LcdInit();
 displayListChar(0, 0, homepage);
 displayListChar(0, 1, email);
 while(1);
ayb_ice 发表于 2007-3-30 13:16 | 显示全部楼层
随便说说
好象是JP,不过这有意义吗?
是串行下载口.
 楼主| 放只 发表于 2007-3-30 14:26 | 显示全部楼层
我查了一下好象是并 口ISP下载口吧?
turmary 发表于 2007-3-30 15:45 | 显示全部楼层
楼上的说的对,就是AT89S51并口ISP下载口
