[cadence] 关于candence16.6的一点疑问
6605|6
 楼主| haijun_chen 发表于 2013-4-1 23:01 | 显示全部楼层 |阅读模式
刚用16.6版本,不知为什么老提示有错误不知道怎么解决。在低版本上没有发现同样问题:以下是错误说明
#1   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device 'CY2305'. JEDEC_TYPE property 'sop-8p127-620x500-pericom-pi6c2405a' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device 'CY2305' has library errors. Unable to transfer to Allegro.
#2   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '841'. JEDEC_TYPE property 'SOP-DIP-16P254-790X2032-ISOCOM-TLP521-4' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '841' has library errors. Unable to transfer to Allegro.
#3   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '842'. JEDEC_TYPE property 'SOP-DIP-16P254-790X2032-ISOCOM-TLP521-4' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '842' has library errors. Unable to transfer to Allegro.
#4   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '670'. JEDEC_TYPE property 'QFP-48P050-900X900-REALTECK-RTL8211CL' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '670' has library errors. Unable to transfer to Allegro.
#5   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-164): Problems with device '299'. JEDEC_TYPE property 'sop-14p127-620x875-philips-74hc14d' is illegal: 'Package name is too long.'.
ERROR(SPMHNI-170): Device '299' has library errors. Unable to transfer to Allegro.
------ Library Paths ------
MODULEPATH =  .
           D:/Cadence/SPB_16.6/share/local/pcb/modules
PSMPATH =  E:/layout/lib/
PADPATH =  E:/layout/lib/
------ Summary Statistics ------
#6   Run stopped because errors were detected
netrev run on Apr 1 22:59:21 2013
   DESIGN NAME : 'DVR-16D1-MAINB-C2-2013-02-27'
   PACKAGING ON Sep 10 2012 04:46:09
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
  6 errors detected
No oversight detected
No warning detected
cpu time      0:01:32
elapsed time  0:00:00
INFO(ORCAP-32005): *** Done ***
jakfens 发表于 2013-4-2 09:04 | 显示全部楼层
一直把candence和cadence混淆
qin552011373 发表于 2013-4-2 21:32 | 显示全部楼层
有一个是错的额
jakfens 发表于 2013-4-3 08:57 | 显示全部楼层
有一个是错的额
呃 我以为都是他们公司的产品
qin552011373 发表于 2013-4-3 10:43 | 显示全部楼层
呃 我以为都是他们公司的产品
497081513 发表于 2016-1-30 14:13 | 显示全部楼层
解决了吗?
gaochy1126 发表于 2016-1-31 21:34 | 显示全部楼层
这个问题。。。
