Proteus仿真DSP
2293|7
 楼主| jlyuan 发表于 2013-4-6 14:48 | 显示全部楼层 |阅读模式
7.9版本的Proteus已经支持TI部分DSP的仿真了,没想到那么小体积的软件能实现那么多的功能,有用过的兄弟过来说说
shimx 发表于 2013-4-6 14:50 | 显示全部楼层
到7.8为止还没听说支持。
你说的7.9,支持哪个系列的dsp呢,有下载吗??
huangchui 发表于 2013-4-6 14:50 | 显示全部楼层
从来没仿真过DSP 51 AVR ARM都仿真过
spark周 发表于 2013-4-6 14:54 | 显示全部楼层
仿真MCU及外设的用得比较多一些,可以仿真51、PIC等等。
但其仿真类型仍有待增强,很多的元件库会找不到。
实际使用中褒贬不一。
如果用TI的产品,使用CCS仿真的更多,可以关注一下。
wyjie 发表于 2013-4-6 14:54 | 显示全部楼层
Proteus VSM for TI TMS320 PICCOLO DSP
See Also» What is Proteus VSM?
» Why use Proteus VSM?
» Proteus VSM in Action
Proteus VSM for TI PICCOLO contains everything you need to develop, test and virtually prototype your embedded system designs based around the popular TMS320 DSP series of microcontrollers from Texas Instruments. The unique nature of schematic based microcontroller simulation with Proteus facilitates rapid, flexible and parallel development of both the system hardware and the system firmware. This design synergy allows engineers to evolve their projects more quickly, empowering them with the flexibility to make hardware or firmware changes at will and reducing the time to market. Proteus VSM is discussed in more detail here.
支持的器件
TMS320F280200, TMS320F28020, TMS320F28021
TMS320F28022,TMS320F28023, TMS320F28026
TMS320F28027
 楼主| jlyuan 发表于 2013-4-6 14:59 | 显示全部楼层
哦,我看看吧
 楼主| jlyuan 发表于 2013-4-6 15:00 | 显示全部楼层
多谢几位指点了
