大虾看看@_@!!
3748|14
 楼主| 发霉的味道 发表于 2007-6-16 23:19 | 显示全部楼层 |阅读模式
#include "reg51.h"
sbit  SPICS = P1^0 ;
sbit  SPISK = P1^1 ;
sbit  SPIDI = P1^2 ;
sbit  SPIDO = P1^3 ;
void delay ( unsigned int timeM )
{  unsigned  int  count;
         TH0  = 0x06 ;
         TL0  = 0x06 ;
         TMOD = 0x02 ;
            TF0  = 0 ;
            TR0  = 1 ;
   for ( ; timeM > 0 ; timeM-- )
       { for ( count=4 ; count>0 ; )
              if ( TF0 ) {   count-- ;
                            TF0 = 0;
void SPIstart ( void )
{     SPICS = 0  ;
      SPISK = 0     ;
      SPIDI = 1     ;
      SPIDO = 1  ;
      delay ( 10 ) ;
      return ;
 void SPIewen ( void )
 {   unsigned char command , count;
      SPIstart () ;
      SPICS = 1 ;
      SPISK = 1 ;
      someNOP() ;
      SPISK = 0 ;
      SPIDI = 0 ;
      SPISK = 1 ;
      someNOP() ;
      SPISK = 0 ;
      SPISK = 1 ;
      someNOP() ;
      SPISK = 0 ;
      command = 0xC0 ;
      for ( count = 0 ; count < 7 ; count ++ )
          {  if ( command & 0x80 ) SPIDI = 1  ;
             else  SPIDI = 0  ;
             command <<= 1   ;
             SPISK = 1 ;
             someNOP() ;
             SPISK = 0 ;
       SPICS = 0 ;
       delay ( 10 ) ;
       return  ;
 void SPIwrite ( unsigned char address , unsigned int wdata )
 {    unsigned char count , waddress ;
      unsigned int databuf ;
      waddress = address , databuf = wdata ;
      SPIewen ()  ;
      SPIstart () ;
      SPICS = 1   ;
      SPISK = 1   ;
      someNOP()   ;
      SPISK = 0   ;
      SPIDI = 0   ;
      SPISK = 1   ;
      someNOP()   ;
      SPISK = 0   ;
      SPIDI = 1   ;
      SPISK = 1   ;
      someNOP()   ;
      SPISK = 0   ;
      for ( count = 0 ; count < 7 ; count ++ )    /*  send the address  */
          {  if ( waddress & 0x80 )     SPIDI = 1  ;
             else  SPIDI = 0   ;
             waddress <<= 1  ;
             SPISK = 1 ;
             someNOP() ;
             SPISK = 0 ;
       for ( count = 0 ; count < 8 ; count ++ )
           {  if ( databuf & 0x80 ) SPIDI = 1  ;
              else  SPIDI = 0  ;
              databuf <<= 1  ;
              SPISK = 1 ;
              someNOP() ;
              SPISK = 0 ;
      SPICS = 0 ;
      delay ( 10 ) ;
      return ;
unsigned char SPIread ( unsigned char address )
      unsigned int wdata ;
      waddress = address ;
      SPIstart () ;
      SPICS = 1 ;
      SPISK = 1 ;
      someNOP() ;
      SPISK = 0 ;
      SPISK = 1   ;
      someNOP() ;
      SPISK = 0   ;
      SPIDI = 0   ;
      SPISK = 1   ;
      someNOP() ;
      SPISK = 0   ;
             else  SPIDI = 0  ;
             waddress <<= 1  ;
             SPISK = 1 ;
             someNOP() ;
             SPISK = 0 ;
        SPIDO = 1  ;
        someNOP ()   ;
            {  SPISK = 1 ;
               someNOP() ;
               SPISK = 0 ;
               wdata <<= 1 ;
               if ( SPIDO == 1 ) wdata = wdata + 1 ;
         SPICS = 0 ;
         return ( wdata );
void main()
{  unsigned char buf [ 8 ] ;
    SPIwrite ( 0x00 , 0x00 ) ;
    buf [ 0 ] = SPIread ( 0x00 ) ;
我的51程序,读写93C46的,一直不成功,不知道是什么原因.请大虾指点,不胜感激!!!
ayb_ice 发表于 2007-6-17 07:55 | 显示全部楼层
仔细看DATASHEET
dreambird 发表于 2007-6-17 12:36 | 显示全部楼层
就这一堆程序贴出来,好歹给个注释啊
毕竟看你的思路比看你的程序容易
平常人 发表于 2007-6-17 13:00 | 显示全部楼层
嘿嘿,是有一点发霉的味道,真不好意思
zhaoyu2005 发表于 2007-6-17 13:31 | 显示全部楼层
好像刚开始编程的大多数不爱加注释
为什么呢?在为怎么写语句发愁,忘了
 楼主| 发霉的味道 发表于 2007-6-17 15:09 | 显示全部楼层
呜呜....
#include "reg51.h"
sbit  SPICS = P1^0 ;
sbit  SPISK = P1^1 ;
sbit  SPIDI = P1^2 ;
sbit  SPIDO = P1^3 ;   //定义IO
void delay ( unsigned int timeM )    //延时子程序(ms)
         TH0  = 0x06 ;
         TL0  = 0x06 ;
         TMOD = 0x02 ;
            TF0  = 0 ;
            TR0  = 1 ;
                            TF0 = 0;
void SPIstart ( void )     //初始化SPI总线
{     SPICS = 0  ;
      SPISK = 0     ;
      SPIDI = 1     ;
      SPIDO = 1  ;
      delay ( 10 ) ;   //延时10MS
      return ;
void SPIewen ( void )   //写允许
      SPIstart () ;     //初始化SPI总线
      SPICS = 1 ;      //片选
      SPISK = 1 ;      //  DI=1 ,SK= 1 ,总线开始位为高电平
      someNOP() ;      //等待稳定
      SPISK = 0 ;
      SPIDI = 0 ;
      SPISK = 1 ;      //   输入数据0
      someNOP() ;
      SPISK = 0 ;
      SPISK = 1 ;     //输入数据0
      someNOP() ;
      SPISK = 0 ;     // 写允许命令高三位输入完毕,100
      command = 0xC0 ;  // 低七位 11*****
      for ( count = 0 ; count < 7 ; count ++ )  //输入低7位
             else  SPIDI = 0  ;
             command <<= 1   ;
             SPISK = 1 ;
             someNOP() ;
             SPISK = 0 ;
       SPICS = 0 ;    //   片选下拉
       return  ;
void SPIwrite ( unsigned char address , unsigned int wdata )//写SPI总线
      SPIewen ()  ;   //写允许
      SPIstart () ;   //重新初始化SPI总线
      SPICS = 1   ;   //片选
      SPISK = 1   ;   //开始位1 ,DI= 1
      someNOP()   ;
      SPISK = 0   ;
      SPIDI = 0   ;
      SPISK = 1   ;   //输入数据0
      someNOP()   ;
      SPISK = 0   ;
      SPIDI = 1   ;
      SPISK = 1   ;   //输入数据1
      someNOP()   ;
      SPISK = 0   ;   //命令高三位101输入完毕
      for ( count = 0 ; count < 7 ; count ++ )   //输入低7位地址
             else  SPIDI = 0   ;
             waddress <<= 1  ;
             SPISK = 1 ;
             someNOP() ;
             SPISK = 0 ;
       for ( count = 0 ; count < 8 ; count ++ )  //输入8位数据
              else  SPIDI = 0  ;
              databuf <<= 1  ;
              SPISK = 1 ;
              someNOP() ;
              SPISK = 0 ;
      SPICS = 0 ;    //片选下拉
      return ;
unsigned char SPIread ( unsigned char address )    //读SPI总线
      SPICS = 1 ;    //片选
      SPISK = 1 ;   //输入开始位1
      someNOP() ;
      SPISK = 0 ;
      SPISK = 1   ;  //输入1
      someNOP() ;
      SPISK = 0   ;
      SPIDI = 0   ;
      SPISK = 1   ;  //输入0
      someNOP() ;
      SPISK = 0   ;   //读命令高三位110输入完毕
             else  SPIDI = 0  ;
             waddress <<= 1  ;
             SPISK = 1 ;
             someNOP() ;
             SPISK = 0 ;
        SPIDO = 1  ;  //  地址输入完毕,准备接收数据
        someNOP ()   ;
        for ( count = 0 ; count < 8 ; count ++ )  //开始接收数据
            {  SPISK = 1 ;
               someNOP() ;
               SPISK = 0 ;
               wdata <<= 1 ;
         SPICS = 0 ;
         return ( wdata );
void main()
    SPIwrite ( 0x00 , 0x00 ) ;  //写地址0X00,数据为0X00
    buf [ 0 ] = SPIread ( 0x00 ) ;  // 读地址0X00,结果读出的数据却不是0X00,却是0XFF???????why??why??why??why??why??why??
读了N多次DATASHEET 没有发现我哪有做错啊?只得前来请大虾指点!!!
mcuatmel 发表于 2007-6-17 15:39 | 显示全部楼层
楼主,先从网上找个现成的,多的是。
试成了之后再改成你的思路的程序不就行了。
 楼主| 发霉的味道 发表于 2007-6-17 18:59 | 显示全部楼层
我就是想自己试试看看!!实在不行再找吧!
dreambird 发表于 2007-6-17 23:35 | 显示全部楼层
DI的建立时间要求是多长?
 楼主| 发霉的味道 发表于 2007-6-18 16:33 | 显示全部楼层
顶起来!
沉下去了,我顶起来!
dreambird 发表于 2007-6-18 20:31 | 显示全部楼层
顶什么,怎么不回答?
      SPISK = 0   ;
      SPIDI = 0   ;
      SPISK = 1   ;  //输入0
上升沿触发?没有建立时间的要求吗?
 楼主| 发霉的味道 发表于 2007-6-18 23:11 | 显示全部楼层
我看过了啊!
DI建立时间是50ns啊,我这个不是足够了吗?
古道热肠 发表于 2007-6-19 11:09 | 显示全部楼层
用别人的程序试硬件,用自已的程序做优化
   找1个可信的程序测试一下硬件也不错,如果硬件没打通,软件再好使,也不知错在哪儿。
  如果别的程序都成正常,就你这程序有问题,对比着看,找到问题后记到本子上,下次别犯同1个错误了。
 楼主| 发霉的味道 发表于 2007-6-19 21:40 | 显示全部楼层
呜.............
......................................一定得这样吗?
 楼主| 发霉的味道 发表于 2007-6-20 13:28 | 显示全部楼层
找到原因了!!
谢谢各侠大虾!我找到原因了!!!原来在写之后有一个状态校验片选时间,偶给忽略了......真是不好意思!!
