具体是什么东西? ************************************* ------------- Call Depth ------------ Depth Interrupt Function ------------------------------------- 0 N ProgramStart 1 Y _interrupt_l 1 Y _interrupt 0 N _main C 1 N _initalization C 1 N _delay02s ------------------------------------- Stack Depth: 1
************************************* -------------- Data Map ------------- d -- Uninitialized data D -- Initialized data b -- Uninitialized bit data B -- Initialized bit data C -- C Register
-------------- RAM Data ------------- 0x00 - - - - - - - - - - - - - - - - 0x10 - - - - - - - - - - - - - - - - 0x20 d d d d d d d b d d d d d d d - 0x30 - - - - - - - - - - - - - - - -
----------- Register Data ----------- 0x00 - d d b d b b - - - - - - - - b 0x10 C - - - - - - - - - - - - - - -
-------------- IO Data -------------- 0x00 - - - - - d d - - - - d d d d d
**************************************** --------------- ROM Code --------------- 000000: 1410 JMP 0x010 [ 16] 000001: 1FFF ADD A, @0xFF [ 255]
按照上面的提示d表示没有初始化的数据,可是我在程序里对的IO data的 0XO5,OX06都赋了值,他们是单片机的PORT5,PORT6端口。简单的功能都调试好了,可里面的东西都没理解. -------------- IO Data -------------- 0x00 - - - - - d d - - - - d d d d d |
