太牛X拉
2463|10
hotpower|  楼主 | 2009-2-17 05:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ov, AC, hm, vr, hd
$NOMOD51
#include <reg51f.h>
    ORG   0000H
RESET:    NOP
    NOP
    NOP
EXTI0:    CLR   008H
    JNB   0C2H,L001D
    SETB  0C2H
    MOV   DPTR,#D1F20
    MOV   A,#000H
    MOVC  A,@A+DPTR
    CJNE  A,#00FH,L0018
EXTI1:    ACALL S03AA
    LJMP  L0517
L0018:    ORL   0B1H,#002H
TIMER1:    SJMP  $
L001D:    MOV   085H,#0FBH
    SETB  0C1H
    SETB  0C3H
    SETB  0C0H
    MOV   SP,#03AH
    ACALL S0047
TIMER2:    ACALL S00E7
    CJNE  A,#055H,TIMER2
    SETB  0C1H
    CLR   0C0H
    MOV   DPTR,#D1F00
    CLR   A
    MOVC  A,@A+DPTR
    CJNE  A,#000H,L0040
    SETB  008H
    SJMP  L0088
L0040:    CJNE  A,#0FFH,L0088
    SETB  008H
    SJMP  L0088
S0047:    MOV   TMOD,#002H
    MOV   T2CON,#030H
    CLR   A
    MOV   TH2,A
    MOV   TL2,A
L0052:    JNB   RXD,$
L0055:    JB    RXD,$
    SETB  TR2
L005A:    JNB   RXD,$
    CLR   TR2
    MOV   A,TL2
    MOV   039H,A
    SWAP  A
    ANL   A,#00FH
    MOV   R0,A
    MOV   A,TH2
    SWAP  A
    ANL   A,#0F0H
    ORL   A,R0
    MOV   R0,A
    MOV   A,TH2
    MOV   038H,A
    SWAP  A
    ANL   A,#00FH
    MOV   R1,A
    MOV   A,R0
    CPL   A
    MOV   TL2,A
    MOV   RCAP2L,A
    MOV   A,R1
    CPL   A
    MOV   TH2,A
    MOV   RCAP2H,A
    SETB  TR2
    MOV   SCON,#052H
    RET
L0088:    MOV   032H,#000H
    ACALL S00E7
    CJNE  A,#03AH,L0088
    ACALL S00C0
    MOV   033H,035H
    ACALL S00C0
    MOV   031H,035H
    ACALL S00C0
    MOV   030H,035H
    ACALL S00C0
    MOV   034H,035H
    MOV   A,033H
    MOV   R2,A
    JZ    L00B2
    MOV   R1,#080H
L00AB:    ACALL S00C0
    MOV   @R1,035H
    INC   R1
    DJNZ  R2,L00AB
L00B2:    MOV   R4,032H
    ACALL S00C0
    MOV   A,R4
    CJNE  A,035H,L00BC
    AJMP  L0106
L00BC:    MOV   A,#058H
    AJMP  L014D
S00C0:    ACALL S00E7
    ACALL S00F1
    SWAP  A
    MOV   035H,A
    ACALL S00E7
    ACALL S00F1
    ORL   035H,A
    MOV   A,032H
    CLR   C
    SUBB  A,035H
    MOV   032H,A
    RET
S00D5:    JNB   TI,$
    CLR   TI
    MOV   SBUF,A
    RET
S00DD:    JNB   RI,$
    CLR   RI
    MOV   A,SBUF
    ANL   A,#07FH
    RET
S00E7:    ACALL S00DD
    ACALL S00D5
    JNB   ACC.6,L00F0
    CLR   ACC.5
L00F0:    RET
S00F1:    JNB   ACC.6,L00F6
    ADD   A,#009H
L00F6:    ANL   A,#00FH
    RET
S00F9:    ANL   A,#00FH
    CLR   C
    SUBB  A,#00AH
    JNC   L0103
    ADD   A,#03AH
    RET
L0103:    ADD   A,#041H
    RET
L0106:    MOV   A,034H
    RL    A
    MOV   DPTR,#L010D
    JMP   @A+DPTR;?
L010D:    AJMP  L0125
L010F:    AJMP  L014B
D0111:    DB    041H,088H;AJMP  L0288;?骗子!!!
D0113:    DB    021H,0BFH;AJMP  L01BF;?骗子!!!(应该为LJMP  L01BF)
D0115:    DB    021H,060H;AJMP  L0160;?骗子!!!(应该为LJMP  L0160)
D0117:    DB    021H,0E3H;AJMP  L01E3;?骗子!!!(应该为LJMP  L01E3)
L0119:  AJMP  L020E
D011B:    DB    041H,08EH;AJMP  L028E;?骗子!!!
D0119:    DB    041H,063H;AJMP  L0263;?骗子!!!(应该为LJMP  L0263)
D011D:    DB    041H,0B5H;AJMP  L02B5;?骗子!!!
L0121:    AJMP  L022B
L0123:    AJMP  L0155;?骗子!!!
L0125:    JNB   008H,L0151
    MOV   DPL,030H
    MOV   DPH,031H
    MOV   R1,#080H
    MOV   A,033H
    JZ    L014B
L0134:    MOV   A,@R1
    MOV   036H,R1
    MOV   R1,#002H
    LCALL S1FF0
    MOV   R1,036H
    JNZ   L0147
    INC   R1
    INC   DPTR
    DJNZ  033H,L0134
    AJMP  L014B
L0147:    MOV   A,#052H
    AJMP  L014D
L014B:    MOV   A,#02EH
L014D:    ACALL S00D5
    AJMP  L01A7
L0151:    MOV   A,#050H
    AJMP  L014D
L0155:    MOV   A,#02EH
    ACALL S00D5
L0159:    JNB   TI,$
    AJMP  L0018
L015E:    AJMP  L014B
L0160:    JNB   008H,L0151
    MOV   R0,#080H
    MOV   DPH,@R0
    INC   R0
    MOV   DPL,@R0
    INC   R0
    MOV   031H,@R0
    INC   R0
    MOV   030H,@R0
    INC   R0
L0171:    JNB   RI,$
    CLR   RI
L0176:    CJNE  @R0,#000H,L0189
    ACALL S01F9
    MOV   R5,#010H
    MOV   A,DPH
    ACALL S0202
    MOV   A,DPL
    ACALL S0202
    MOV   A,#03DH
    ACALL S00D5
L0189:    MOV   R1,#003H
    LCALL S1FF0
    CJNE  @R0,#000H,L0195
    ACALL S0202
    SJMP  L0198
L0195:    CJNE  A,#0FFH,L01B5
L0198:    MOV   A,031H
    CJNE  A,DPH,L01B0
    MOV   A,030H
    CJNE  A,DPL,L01B0
    CJNE  @R0,#001H,L01A7
    AJMP  L014B
L01A7:    ACALL S01F9
L01A9:    JNB   TI,$
    SETB  REN
    AJMP  L0088
L01B0:    INC   DPTR
    DJNZ  R5,L0189
    AJMP  L0176
L01B5:    MOV   A,DPH
    ACALL S0202
    MOV   A,DPL
    ACALL S0202
    AJMP  L01A7
L01BF:    JNB   008H,L0151
    MOV   R1,#080H
    MOV   037H,@R1
    CJNE  @R1,#001H,L01CB
    SJMP  L01DC
L01CB:    CJNE  @R1,#005H,L01D3
    INC   R1
    MOV   DPL,@R1
    SJMP  L01DC
L01D3:    CJNE  @R1,#008H,L01E1
    INC   R1
    MOV   DPH,@R1
    INC   R1
    MOV   DPL,@R1
L01DC:    MOV   R1,037H
    LCALL S1FF0
L01E1:    AJMP  L014B
L01E3:    JNB   008H,L0229
    MOV   R1,#080H
    MOV   037H,@R1
    INC   R1
    MOV   DPL,@R1
    MOV   DPH,#000H
    MOV   R1,037H
    LCALL S1FF0
    ACALL S0202
    AJMP  L014B
S01F9:    MOV   A,#00DH
    ACALL S00D5
    MOV   A,#00AH
    ACALL S00D5
    RET
S0202:    MOV   R4,A
    SWAP  A
    ACALL S00F9
    ACALL S00D5
    MOV   A,R4
    ACALL S00F9
    ACALL S00D5
    RET
L020E:    MOV   A,#02EH
    ACALL S00D5
    MOV   R1,#0FFH
L0214:    DJNZ  R1,$
L0216:    DJNZ  R1,$
    MOV   R1,#080H
    CLR   TR2
    MOV   TH2,@R1
    MOV   RCAP2H,@R1
    INC   R1
    MOV   TL2,@R1
    MOV   RCAP2L,@R1
    SETB  TR2
    AJMP  L01A7
L0229:    AJMP  L0151
L022B:    JNB   008H,L0229
    MOV   DPTR,#D1F00
    MOV   031H,#01FH
    MOV   030H,#07FH
L0237:    ACALL S01F9
    MOV   R5,#010H
    MOV   A,DPH
    ACALL S0202
    MOV   A,DPL
    ACALL S0202
    MOV   A,#03DH
    ACALL S00D5
L0247:    CLR   A
    MOVC  A,@A+DPTR
    ACALL S0202
    MOV   A,031H
    CJNE  A,DPH,L025E
    MOV   A,030H
    CJNE  A,DPL,L025E
    ACALL S01F9
L0257:    JNB   TI,$
    SETB  REN
    AJMP  L0088
L025E:    INC   DPTR
    DJNZ  R5,L0247
    AJMP  L0237
L0263:    SETB  008H
    MOV   R1,#080H
    MOV   DPTR,#D1F00
    CLR   A
    MOVC  A,@A+DPTR
    MOV   R2,A
    INC   DPTR
    JZ    L0286
    CJNE  A,#0FFH,L0275
    SJMP  L0286
L0275:    XRL   A,033H
    JZ    L027B
    CLR   008H
L027B:    CLR   A
    MOVC  A,@A+DPTR
    XRL   A,@R1
    JZ    L0282
    CLR   008H
L0282:    INC   DPTR
    INC   R1
    DJNZ  R2,L027B
L0286:    AJMP  L014B
D0288:    DB    079H,09FH,077H,00FH,080H,004H,079H,09FH
D0290:    DB    077H,000H,075H,0F0H,001H,071H,07FH,071H
D0298:    DB    099H,051H,0ABH,075H,0F0H,002H,071H,07FH
D02A0:    DB    075H,033H,000H,0D2H,009H,0D2H,008H,080H
D02A8:    DB    010H,021H,051H,079H,080H,078H,01FH,077H
D02B0:    DB    0FFH,009H,0D8H,0FBH,022H,079H,09FH,077H
D02B8:    DB    000H,030H,008H,0EDH,075H,0F0H,003H,071H
D02C0:    DB    07FH,075H,0A2H,000H,090H,03FH,080H,075H
D02C8:    DB    0A2H,001H,090H,000H,000H,078H,080H,075H
D02D0:    DB    0A2H,000H,0E4H,093H,0A3H,075H,0A2H,001H
D02D8:    DB    0F0H,0A3H,0D8H,0F3H,075H,0F0H,004H,071H
D02E0:    DB    07FH,090H,03FH,080H,071H,0AAH,075H,0F0H
D02E8:    DB    005H,071H,07FH,075H,0A2H,000H,090H,01FH
D02F0:    DB    080H,075H,0A2H,001H,090H,03FH,080H,078H
D02F8:    DB    00EH,075H,0A2H,000H,0E4H,093H,0A3H,075H
D0300:    DB    0A2H,001H,071H,0BBH,0A3H,0D8H,0F2H,075H
D0308:    DB    0F0H,006H,071H,07FH,043H,0B1H,040H,075H
D0310:    DB    0B4H,01FH,075H,0B3H,000H,012H,03FH,085H
D0318:    DB    075H,0F0H,007H,071H,07FH,0E5H,033H,020H
D0320:    DB    009H,002H,060H,03CH,075H,082H,000H,075H
D0328:    DB    083H,01FH,043H,0B1H,040H,085H,083H,0B4H
D0330:    DB    085H,082H,0B3H,0F5H,0B5H,012H,03FH,080H
D0338:    DB    075H,0F0H,008H,071H,07FH,079H,080H,075H
D0340:    DB    033H,020H,030H,009H,002H,0C2H,009H,043H
D0348:    DB    0B1H,040H,0A3H,085H,083H,0B4H,085H,082H
D0350:    DB    0B3H,0E7H,0F5H,0B5H,012H,03FH,080H,009H
D0358:    DB    0D5H,033H,0ECH,075H,0F0H,009H,071H,07FH
D0360:    DB    090H,03FH,080H,071H,0AAH,075H,0F0H,00AH
D0368:    DB    071H,07FH,090H,03FH,080H,078H,000H,07AH
D0370:    DB    080H,0E2H,071H,0BBH,008H,0A3H,0DAH,0F9H
D0378:    DB    075H,0F0H,00BH,071H,07FH,021H,04BH,0C0H
D0380:    DB    0E0H,074H,020H,0E5H,0F0H,0D0H,0E0H,022H
S0388:    MOV   A,DPL
    CJNE  A,#000H,L0390
    MOV   A,#0BFH
    RET
L0390:    CJNE  A,#001H,L0396
    MOV   A,#091H
    RET
L0396:    MOV   A,#005H
    RET
S0399:    ORL   0B1H,#040H
    MOV   0B4H,#0F0H
    MOV   0B5H,#055H
    MOV   0B2H,#00DH
    ACALL S04A0
    MOV   A,#000H
    RET
S03AA:    ORL   0B1H,#040H
    MOV   0B4H,DPH
    MOV   0B3H,DPL
    MOV   0B2H,#00BH
    ACALL S04A0
    MOV   A,#000H
    RET
S03BB:    ORL   0B1H,#040H
    MOV   0B4H,DPH
    MOV   0B3H,DPL
    MOV   0B5H,A
    MOV   B,A
    MOV   0B2H,#00EH
    ACALL S04A0
    ORL   0B1H,#040H
    MOV   0B4H,DPH
    MOV   0B3H,DPL
    MOV   0B2H,#00CH
    MOV   A,0B5H
    XRL   A,B
    RET
S03DE:    ORL   0B1H,#040H
    MOV   0B4H,DPH
    MOV   0B3H,DPL
    MOV   0B2H,#00CH
    MOV   A,0B5H
    RET
S03ED:    MOV   A,DPL
    MOV   DPTR,#L03F5
    ADD   A,ACC
    JMP   @A+DPTR;?
L03F5:    AJMP  L0401
L03F7:    AJMP  L040D
L03F9:    AJMP  L0419
L03FB:    AJMP  L0425
L03FD:    AJMP  L0434
L03FF:    AJMP  L0443
L0401:    ORL   0B1H,#040H
    MOV   0B5H,#0AAH
    MOV   0B2H,#00FH
    ACALL S04A0
    RET
L040D:    ORL   0B1H,#040H
    MOV   0B5H,#0AAH
    MOV   0B2H,#003H
    ACALL S04A0
    RET
L0419:    ORL   0B1H,#040H
    MOV   0B5H,#0AAH
    MOV   0B2H,#005H
    ACALL S04A0
    RET
L0425:    ORL   0B1H,#040H
    MOV   0B4H,#05AH
    MOV   0B5H,#0AAH
    MOV   0B2H,#009H
    ACALL S04A0
    RET
L0434:    ORL   0B1H,#040H
    MOV   0B4H,#0AAH
    MOV   0B5H,#0AAH
    MOV   0B2H,#009H
    ACALL S04A0
    RET
L0443:    MOV   A,0B6H
    JB    ACC.3,L0486
L0448:    JNB   TI,$
    ORL   0B1H,#040H
    MOV   0B4H,#055H
    MOV   0B5H,#0AAH
    MOV   0B2H,#008H
    ACALL S04A0
    CLR   TR2
    MOV   A,038H
    RRC   A
    CLR   ACC.7
    MOV   R1,A
    MOV   A,039H
    RRC   A
    MOV   R0,A
    MOV   A,R1
    RRC   A
    CLR   ACC.7
    MOV   R1,A
    MOV   A,R0
    RRC   A
    MOV   R0,A
    MOV   A,R1
    RRC   A
    CLR   ACC.7
    CPL   A
    MOV   R1,A
    MOV   A,R0
    RRC   A
    CPL   A
    CLR   C
    ADD   A,#001H
    MOV   RCAP2L,A
    MOV   TL2,A
    MOV   A,R1
    ADDC  A,#000H
    MOV   RCAP2H,A
    MOV   TH2,A
    SETB  TR2
L0486:    CLR   A
    RET
S0488:    MOV   A,0B6H
    MOV   C,ACC.3
    MOV   ACC.4,C
    SWAP  A
    ANL   A,#00FH
    MOV   C,008H
    MOV   ACC.4,C
    MOV   R1,#09FH
    CJNE  @R1,#00FH,L049D
    SETB  ACC.5
    RET
L049D:    CLR   ACC.5
    RET
S04A0:    MOV   A,0B6H
    JB    ACC.2,S04A0
    RET
L04A6:    CJNE  R1,#000H,L04AD
    ACALL S0388
    SJMP  L04E1
L04AD:    CJNE  R1,#001H,L04B4
    ACALL S0399
    SJMP  L04E1
L04B4:    CJNE  R1,#002H,L04BB
    ACALL S03BB
    SJMP  L04E1
L04BB:    CJNE  R1,#003H,L04C2
    ACALL S03DE
    SJMP  L04E1
L04C2:    CJNE  R1,#004H,L04C7
    SJMP  L04E1
L04C7:    CJNE  R1,#005H,L04CE
    ACALL S03ED
    SJMP  L04E1
L04CE:    CJNE  R1,#006H,L04D3
    SJMP  L04E1
L04D3:    CJNE  R1,#007H,L04DA
    ACALL S0488
    SJMP  L04E1
L04DA:    CJNE  R1,#008H,L04E1
    ACALL S03AA
    SJMP  L04E1
L04E1:    RET
hotpower|  楼主 | 2009-2-17 05:30 | 只看该作者
D04E2:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D04EA:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D04F2:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D04FA:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0502:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D050A:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0512:    DB    0FFH,0FFH,0FFH,0FFH,0FFH
L0517:    SJMP  $
D0519:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0521:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0529:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0531:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0539:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0541:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0549:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0551:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0559:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0561:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0569:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0571:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0579:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0581:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0589:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0591:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0599:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D05F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0601:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0609:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0611:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0619:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0621:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0629:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0631:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0639:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0641:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0649:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0651:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0659:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0661:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0669:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0671:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0679:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0681:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0689:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0691:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0699:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D06F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0701:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0709:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0711:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0719:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0721:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0729:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0731:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0739:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0741:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0749:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0751:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0759:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0761:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0769:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0771:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0779:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0781:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0789:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0791:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0799:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D07F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0801:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0809:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0811:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0819:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0821:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0829:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0831:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0839:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0841:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0849:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0851:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0859:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0861:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0869:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0871:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0879:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0881:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0889:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0891:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0899:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D08F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0901:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0909:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0911:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0919:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0921:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0929:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0931:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0939:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0941:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0949:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0951:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0959:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0961:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0969:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0971:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0979:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0981:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0989:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0991:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0999:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D09F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0A99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0AF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0B99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0BF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0C99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0CF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0D99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0DF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0E99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0ED1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0ED9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0EF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0F99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D0FF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1001:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1009:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1011:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1019:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1021:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1029:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1031:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1039:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1041:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1049:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1051:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1059:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1061:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1069:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1071:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1079:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1081:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1089:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1091:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1099:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D10F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1101:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1109:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1111:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1119:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1121:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1129:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1131:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1139:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1141:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1149:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1151:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1159:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1161:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1169:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1171:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1179:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1181:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1189:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1191:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1199:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D11F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1201:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1209:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1211:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1219:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1221:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1229:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1231:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1239:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1241:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1249:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1251:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1259:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1261:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1269:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1271:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1279:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1281:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1289:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1291:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1299:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D12F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1301:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1309:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1311:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1319:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1321:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1329:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1331:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1339:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1341:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1349:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1351:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1359:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1361:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1369:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1371:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1379:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1381:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1389:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1391:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1399:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D13F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1401:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1409:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1411:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1419:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1421:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1429:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1431:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1439:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1441:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1449:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1451:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1459:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1461:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1469:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1471:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1479:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1481:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1489:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1491:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1499:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D14F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1501:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1509:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1511:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1519:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1521:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1529:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1531:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1539:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1541:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1549:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1551:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1559:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1561:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1569:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1571:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1579:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1581:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1589:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1591:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1599:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D15F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1601:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1609:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1611:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1619:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1621:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1629:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1631:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1639:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1641:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1649:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1651:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1659:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1661:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1669:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1671:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1679:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1681:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1689:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1691:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1699:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D16F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1701:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1709:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1711:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1719:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1721:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1729:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1731:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1739:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1741:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1749:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1751:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1759:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1761:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1769:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1771:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1779:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1781:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1789:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1791:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1799:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D17F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1801:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1809:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1811:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1819:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1821:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1829:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1831:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1839:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1841:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1849:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1851:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1859:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1861:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1869:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1871:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1879:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1881:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1889:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1891:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1899:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D18F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1901:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1909:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1911:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1919:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1921:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1929:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1931:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1939:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1941:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1949:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1951:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1959:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1961:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1969:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1971:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1979:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1981:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1989:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1991:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1999:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19A1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19A9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19B1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19B9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19C1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19C9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19D1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19D9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19E1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19E9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19F1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D19F9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1A99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1AF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1B99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1BF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1C99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1CF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1D99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DD1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DD9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1DF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E01:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E09:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E11:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E19:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E21:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E29:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E31:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E39:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E41:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E49:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E51:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E59:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E61:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E69:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E71:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E79:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E81:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E89:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E91:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1E99:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EA1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EA9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EB1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EB9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EC1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EC9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1ED1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1ED9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EE1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EE9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EF1:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1EF9:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F00:    DB    000H,000H,000H,000H,000H,000H,000H,000H
D1F08:    DB    000H,000H,000H,000H,000H,000H,000H,000H
D1F10:    DB    000H,000H,000H,000H,000H,000H,000H,000H
D1F18:    DB    000H,000H,000H,000H,000H,000H,000H,000H
D1F20:    DB    000H,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F28:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F30:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F38:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F40:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F48:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F50:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F58:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F60:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F68:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F70:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F78:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F80:    DB    075H,0B2H,00EH,080H,003H,075H,0B2H,00BH
D1F88:    DB    0E5H,0B6H,020H,0E2H,0FBH,022H,0FFH,0FFH
D1F90:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1F98:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FA0:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FA8:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FB0:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FB8:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FC0:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FC8:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FD0:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FD8:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FE0:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FE8:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
S1FF0:    LJMP  L04A6
D1FF3:    DB    0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
D1FFB:    DB    0FFH,0FFH,0FFH,0FFH,0FFH
    END
hotpower|  楼主 | 2009-2-17 08:02 | 只看该作者
最近没时间~~~
yewuyi| | 2009-2-17 08:46 | 只看该作者
又反汇编的啥。。。
古道热肠| | 2009-2-17 12:08 | 只看该作者
好东西,收下了,编译通过,先慢慢理解
Program Size: data=8.0 xdata=0 code=8192
古道热肠| | 2009-2-17 12:11 | 只看该作者
哈哈,帮hot打了个包,用起来方便
夏风| | 2009-2-17 12:40 | 只看该作者
晕晕
王紫豪| | 2009-2-17 14:38 | 只看该作者
太牛X拉
hotpower|  楼主 | 2009-2-17 18:53 | 只看该作者
哈哈~~~但的“代码和数据分离”技术是不可能编译错的~~~
例如下列扫描列表问题中有"*",不用任何编译软件俺就知道有几处错~~~
如:*02B5
哈哈~~~80年代研究的“代码和数据分离”技术到现在也无人超越,
十分之郁闷~~~
小朋友让俺“开源”,你说晕不晕~~~
俺不想把它 放出去“祸害人间”~~~
***_Disasm51_system_simulate_***
$0003
$0018
$001D
$0040
$0047
$0088
$00BC
$00C0
$00E7
$00D5
$00DD
$00F1
$0106
$014D
$01A7
$01F9
$03AA
$04A0
$0517
***_Disasm51_file_P1.def_simulate_***
$010D
$0125
$0147
$014B
$0151
$1FF0
$04A6
$0388
$0390
$0396
$04AD
$0399
$04B4
$03BB
$04BB
$03DE
$04C2
$04C7
$03ED
$04CE
$04D3
$0488
$049D
$04DA
$04E1
$010F
$03F5
$0401
$03F7
$040D
$03F9
$0419
$03FB
$0425
$03FD
$0434
$03FF
$0443
$00F9
$0103
$0155
$015E
$0160
$0195
$01B0
$01B5
$0202
$01BF
$01CB
$01D3
$01E3
$0229
$020E
$022B
$025E
$0263
$0275
*02B5
***Disasm51_file_disasm51.def_simulate_***
$0000
hotpower|  楼主 | 2009-2-17 18:56 | 只看该作者
那个ISP的反汇编里藏着“5个骗子”,以后给您玩~~~
L0109:    MOV   DPTR,#010DH
L010C:    JMP   @A+DPTR;?
L010D:    AJMP  L0125
L010F:    AJMP  L014B
L0111:    AJMP  L0288;?骗子!!!
L0113:    AJMP  L01BF
L0115:    AJMP  L0160
L0117:    AJMP  L01E3
L0119:    AJMP  L020E;?骗子!!!
L011B:    AJMP  L028E;?骗子!!!
L011D:    AJMP  L0263;?骗子!!!
L011F:    AJMP  L02B5;?骗子!!!
L0121:    AJMP  L022B;?骗子!!!
L0123:    AJMP  L0155
