哪位大哥知道一款ADC的芯片,采样率大于10M,量化位数16bit,
7864|10
perhaha|  楼主 | 2009-3-17 15:14 | 只看该作者
re
小女子只知道芯片要求,不知道芯片名字
是不是大海捞针啊....
如果有见过这种芯片的告诉俺一下
ayb_ice| | 2009-3-17 20:41 | 只看该作者
这样的ADC贵的吓人呀
mohanwei| | 2009-3-17 21:22 | 只看该作者
估计是对华禁售的……
stghl| | 2009-3-17 21:25 | 只看该作者
可能有
你去TI网站看一下,大多数都是12BIT,说不定对华不售....
ayb_ice| | 2009-3-17 21:51 | 只看该作者
12位和16位不是一个概念
程疗匠人| | 2009-3-17 22:19 | 只看该作者
ADC
8 Results  http://focus.ti.com/graphics/shared/spacer.gifhttp://focus.ti.com/graphics/shared/spacer.gif
  [TR][TR][TR][TR][TR][TR][TR]
Part Number  Status  Resolution (Bits)  Thermal Shutdown  Architecture  Reference Mode  # Input Channels  Power Consumption (typ) (mW)  SINAD (dB)  Sample Rate (max)  Serial Interface  SNR (dB)  SFDR (dB)  DNL (max) (+/-LSB)  INL (max) (+/-LSB)  No Missing Codes (Bits)  ENOB (Bits)  No. of Supplies  Analog Voltage AV/DD (min) (V)  Analog Voltage AV/DD (max) (V)  Logic Voltage DV/DD (min) (V)  Logic Voltage DV/DD (max) (V)  Input Configuration Range  Differential Inputs  Internal Reference Buffer  LVDS  Parallel Interface  Serial SPI Interface  Rating  Pin/Package  Approx. Price (US$)  http://focus.ti.com/graphics/shared/spacer.gif
Description
 http://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow-red.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gifhttp://focus.ti.com/graphics/shared/uparrow.gif  http://focus.ti.com/graphics/shared/downarrow.gif
ADS5562ACTIVE  16  No  Pipeline  Int and Ext  1  865  80.5  80MSPS   84  85  0.95  8.5  16  13.1  2  3.0  3.6  3.0  3.6  3.6Vpp  Yes   Yes  Yes  Yes  Catalog  48QFN60.45 | 100u  16-bit 80MSPS Low Power ADC with Selectable LVDS/CMOS Outputs  ADS5560ACTIVE  16  No  Pipeline  Int and Ext  1  674  83.2  40MSPS   84.3  90  0.95  8.5  16  13.5  2  3.0  3.6  3.0  3.6  3.6 Vpp  Yes   Yes  Yes  Yes  Catalog  48QFN39.75 | 100u  16-bit 40MSPS Low Power ADC with Selectable LVDS/CMOS Outputs  ADS5485NEW
ACTIVE
16  No  Pipeline  Int and Ext  1  2160  73.7  200MSPS   75  87  1  10  16  11.95  2  4.75  5.25  3  3.6  3.0 Vpp  Yes   Yes  Yes  Yes  Catalog  64VQFN123.70 | 100u  16-bit, 200 MSPS ADC with buffered inputs  ADS5484NEW
ACTIVE
16  No  Pipeline  Int and Ext  1  2160  74.3  170MSPS  Yes  75.7  87  1  10  16  12.05  2  4.75  5.25  3  3.6  3.0 Vpp  Yes   Yes  Yes   Catalog  64VQFN98.70 | 100u  16-bit, 170 MSPS ADC with buffered inputs  ADS5483ACTIVE  16  No  Pipeline  Int and Ext  1  2100  77.8  135MSPS   79  97  0.5  3  16  12.63  2  4.75  5.25  3  3.6  3.0 Vpp   Yes  Yes  Yes   Catalog  64VQFN81.25 | 100u  16-bit 135MSPS ADC with buffered inputs  ADS5482NEW
ACTIVE
16  No  Pipeline  Int and Ext  1  2100  79.3  105MSPS   80.5  98  0.5  3  16  12.88  2  4.75  5.25  3  3.6  3.0 Vpp    Yes  Yes   Catalog  64VQFN70.85 | 100u  16-bit, 105MSPS High Speed ADCs  ADS5481NEW
ACTIVE
16  No  Pipeline  Int and Ext  1  2100  79.5  80MSPS   80.6  98  0.5  3  16  12.91  2  4.75  5.25  3  3.6  3.0 Vpp    Yes  Yes   Catalog  64VQFN60.45 | 100u  16-bit 80MSPS ADC With Buffered Analog Input  ADS1610ACTIVE  16  No  Delta-Sigma  Ext  1  960  83  10MSPS   83  109  0.5  0.4  16   2  4.9  5.1  2.7  3.6  Vref  Yes    Yes   Catalog  64HTQFP21.35 | 1ku  16-Bit, 10MSPS Delta-Sigma Analog-to-Digital Converter
hotpower| | 2009-3-17 22:30 | 只看该作者
不会便宜
宇宙飞船| | 2009-3-17 22:53 | 只看该作者
如果你的PCB信噪比没有达到100DB 根本就发挥
不出这个AD的解析度!以2。5V的基准算,也就是38uv 噪声波动!
这个精度,除了电子称,录音前置用得多以外,应用到一般的产品,
根本就是浪费!!
小民工| | 2009-3-18 08:47 | 只看该作者
16位精度
   忒吓人了,这样的芯片给我也没用
huangqi412| | 2009-3-18 08:55 | 只看该作者
汗,,,不是毕业设计写论文吧...
