µVision4 Beta Download
3394|2
 楼主| 程疗匠人 发表于 2009-3-29 17:37 | 显示全部楼层 |阅读模式
The uVision4 Beta 1 may be installed as add-on to the following products:
  • Keil C51 Version 8.17
  • Keil C166 Version 6.17
  • Keil C251 Version 4.55
  • Keil MDK-ARM Version 3.40
The installation is a true add-on, which means that the functionality of your orignal tool installation is not altered in any form.  After installation of the beta version, you may either use uVision4 or uVision3 to manage your projects.
This download includes the uVision4 IDE/Debugger along with a Getting Started Guide.
Please help us to improve the product and report any suggestions to support.intl@keil.com with UV4 in the subject line.UVISION4BETA1.ZIP (8,179K)
Saturday, February 28, 2009
Estimated File Download Time:
< 36 Minutes: 56Kb Modem
< 16 Minutes: 128Kb ISDN
< 2 Minutes: T1/Broadband
大漠孤烟 发表于 2009-3-29 20:02 | 显示全部楼层
版本更新挺快哦
现在都UV4了
hotpower 发表于 2009-3-29 22:11 | 显示全部楼层
2003的风格,现在c#,vb.net都是这种风格,就是太慢
而且还是不支持只能感知功能,很是郁闷
