12864液晶程序显示不正确的问题
3233|2
 楼主| fzpxp 发表于 2009-4-2 14:46 | 显示全部楼层 |阅读模式
刚学液晶操作,写个了程序,目的是在屏幕左上角写“A”“B”两个字符。
但意向不到的情况出现了,下面是代码,图片是运行结果
请各位帮看看,到底是哪里写错了?才出现这种情况
#include <reg52.h>
#include <stdlib.h>
#include <intrins.h>
#include <stdio.h>
#include <math.h>
#define uchar unsigned char
#define uint unsigned int
/********************引脚定义********************/
#define DataPort P1      //LCD128*64 I/O 信号管脚
sbit    CS1=P2^0;      //左片选
sbit    CS2=P2^1;      // 右片选
sbit    RS=P2^2;      //数据指令
sbit    RW=P2^3;      //读写
sbit    E=P2^4;      //使能
//uchar Page;             //页 地址
//uchar Col;              //列 地址
unsigned char code ASC_5x7[] ={
0x32, 0x49, 0x79, 0x41, 0x3E, //@
0x7E, 0x11, 0x11, 0x11, 0x7E, //A
0x41, 0x7F, 0x49, 0x49, 0x36, //B
0x3E, 0x41, 0x41, 0x41, 0x22, //C
0x41, 0x7F, 0x41, 0x41, 0x3E, //D
0x7F, 0x49, 0x49, 0x49, 0x49, //E
0x7F, 0x09, 0x09, 0x09, 0x01, //F
0x3E, 0x41, 0x41, 0x49, 0x7A, //G
0x7F, 0x08, 0x08, 0x08, 0x7F, //H
0x00, 0x41, 0x7F, 0x41, 0x00, //I
0x20, 0x40, 0x41, 0x3F, 0x01, //J
0x7F, 0x08, 0x14, 0x22, 0x41, //K
0x7F, 0x40, 0x40, 0x40, 0x40, //L
0x7F, 0x02, 0x0C, 0x02, 0x7F, //M
0x7F, 0x06, 0x08, 0x30, 0x7F, //N
0x3E, 0x41, 0x41, 0x41, 0x3E, //O
/********************函数定义*******************/
void Delay(uint ms);       //延时
void Locatexy(void);       //将屏幕横向0-12纵向0-7转换成左、右屏的的X、Y
void WriteCommand( uchar CommandByte );    //写指令
void WriteData( uchar DataByte );    //写数据
void LcmClear( void );       //清屏
void LcmInit( void );        //初始化
/*      写指令             */
{        E = 0;
        CS1=0;    //设置片选
        RS = 0;         //指令
        RW = 0;
        DataPort = CommandByte;
        E = 1;
                  Delay(2);
                  E = 0;
         Delay(2);
            CS1=1;    //设置片选
/*       写数据            */
{        E = 0;
        CS1=0;    //设置片选
        RS = 1;         /*数据输出*/
        RW = 0;         /*写输出 */
        DataPort = DataByte; /*数据输出到数据口 */
        E = 1;            /*写入到LCM*/
       Delay(2);
        E = 0;
      Delay(2);
      CS1=1;    //设置片选
/*         清屏            */
{       uchar Page;uchar Col;
        Page = 0;
        Col = 0;
        for(Page=0;Page<8;Page++)
            for(Col=0;Col<64;Col++)
            {        WriteData(0x00);
            WriteCommand(0x0B8+Page);    //设置页X,DataByte=1011,1???(?为X地址)
/*       初始化            */
    WriteCommand(0x3f);    //开显示
        WriteCommand(0x0C0);    //设置起始地址行DataByte=11??,????
                                 (?为起始行0-63)
       WriteCommand(0x40);    //设置AddressY,DataByte=01??,????
                                   (?为Y 地址)
        WriteCommand(0x0B8);    //设置页X,DataByte=1011,1???
                                     (?为X地址)
        LcmClear();
/*       延时              */
void Delay(uint MS)
    uchar us,usn;
    while(MS!=0)
            usn = 2;        //for 12M
            while(usn!=0)
                    us=0xf6;
                    while (us!=0){us--;};
                    usn--;
            MS--;
/*       写一个字符        */
void PutAsc( uchar asc )
        uchar j;
        uint x;
        x = 5*(asc-32);//asc为字模的位置,32.Means从@、A、B、C、D…O、……开始取字模
            for(j=0;j<5;j++)                   //每个字模是5列数
                        WriteData(ASC_5x7[x]);//x为字模数组中的位置
                        x++;
void Main( void )
     LcmInit();
     PutAsc(33);//显示A
     PutAsc(34);//显示B
     while(1);
半文盲 发表于 2009-4-3 22:27 | 显示全部楼层
给你个参考程序
http://item.taobao.com/auction/item_detail-0db1-ba43433eb2529250b86255b37925f645.htm
http://www.lcdmk.com/html/chanpinzhanshi/tuxingdianzhenyejingmokuai/12864xilie/5849.html
glf 发表于 2009-8-12 09:36 | 显示全部楼层
            {        WriteData(0x00);
是应该这样吧
