求个大神帮我看看这个例程 为什么没有串口通信
1706|4
 楼主| singe0915 发表于 2013-4-11 10:50 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<math.h>
#include<absacc.h>
#include <stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
unsigned char code table[] = {0x3f,0x06,0x5b,0x4f,
                              0x66,0x6d,0x7d,0x07,
                              0x7f,0x6f,0x77,0x7c,
                              0x39,0x5e,0x79,0x71,0X40,0X00};
void send_char(unsigned char txd);
unsigned char tmp;
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^5;
sbit lcdrs=P3^7;
uchar code tab[]="0123456789abcdef";
uchar tab_key[50];
uchar n=0,temp,key;
void lcd_disp();
void lcd_init();
void display(unsigned char);
void write_com(uchar);
void write_data(uchar);
void delay(unit);
void key_scan();
void key_manage1();
void key_manage2();
void key_manage3();
void key_manage4();
void key_manage5();
void key_manage6();
void key_manage7();
void key_manage8();
void key_manage9();
void key_manage10();
void key_manage11();
void key_manage12();
void key_manage13();
void key_manage14();
void key_manage15();
void key_manage16();
void lcd_disp()
         uchar a,i=0;
         write_com(0x80);
        i=0;
        while(i<n)
            a=tab_key[i];
            write_data(tab[a]);
            i++;
            if(i==15)
              write_com(0x80+0x40);
void lcd_init()
         dula=0;
         wela=0;
         lcden=0;
         write_com(0x38);
         write_com(0x0c);
        write_com(0x06);
                write_com(0x80);
       // write_com(0x80+0x40);
void write_com(uchar com)
         lcdrs=0;
         P2=com;
         delay(3);
         lcden=1;
         delay(5);
         lcden=0;
void write_data(uchar dat)
         lcdrs=1;
         P2=dat;
         delay(3);
         lcden=1;
         delay(5);
         lcden=0;
void key_scan()
         P1=0xfe;
         temp=P1;
         temp=temp&0xf0;
         if(temp!=0xf0)
                         delay(100);
                         if(temp!=0xf0)
                                         temp=P1;
                                         switch(temp)
                                                         case 0xee:   key_manage1();display(0);   break;
                                                         case 0xde:   key_manage2();display(1);   break;
                                                         case 0xbe:   key_manage3();display(2);   break;
                                                         case 0x7e:   key_manage4();display(3);   break;
                                         while(temp!=0xf0)
                                                         temp=P1;
                                                         temp=temp&0xf0;
         P1=0xfd;
                 temp=P1;
                 temp=temp&0xf0;
                 if(temp!=0xf0)
                                 delay(100);
                                 if(temp!=0xf0)
                                                 temp=P1;
                                                 switch(temp)
        case 0xed:   key_manage5();display(4);   break;
        case 0xdd:   key_manage6();display(5);   break;
        case 0xbd:   key_manage7();display(6);   break;
        case 0x7d:   key_manage8();display(7);   break;
                                                 while(temp!=0xf0)
        temp=P1;
        temp=temp&0xf0;
         P1=0xfb;
                 temp=P1;
                 temp=temp&0xf0;
                 if(temp!=0xf0)
                                 delay(100);
                                 if(temp!=0xf0)
                                                 temp=P1;
                                                 switch(temp)
        case 0xeb:   key_manage9();display(8);    break;
        case 0xdb:   key_manage10();display(9);   break;
        case 0xbb:   key_manage11();display(10);   break;
        case 0x7b:   key_manage12();display(11);   break;
                                                 while(temp!=0xf0)
        temp=P1;
        temp=temp&0xf0;
         P1=0xf7;
         temp=P1;
         temp=temp&0xf0;
         if(temp!=0xf0)
                         delay(100);
                         if(temp!=0xf0)
                                         temp=P1;
                                         switch(temp)
                                                         case 0xe7:   key_manage13();display(12);   break;
                                                         case 0xd7:   key_manage14();display(13);   break;
                                                         case 0xb7:   key_manage15();display(14);   break;
                                                         case 0x77:   key_manage16();display(15);   break;
                                         while(temp!=0xf0)
                                                         temp=P1;
                                                         temp=temp&0xf0;
void display(unsigned char S)
  P0 = table[S];
delay(200);
P2 = 0x7f;
void delay(uint k)
         uint i,j;
         for(i=k;i>0;i--)
         for(j=50;j>0;j--);
void key_manage1()
         tab_key[n]=0;
         n++;
void key_manage2()
         tab_key[n]=1;
         n++;
void key_manage3()
         tab_key[n]=2;
         n++;
void key_manage4()
         tab_key[n]=3;
         n++;
void key_manage5()
         tab_key[n]=4;
         n++;
void key_manage6()
         tab_key[n]=5;
         n++;
void key_manage7()
         tab_key[n]=6;
         n++;
void key_manage8()
         tab_key[n]=7;
         n++;
void key_manage9()
         tab_key[n]=8;
         n++;
void key_manage10()
         tab_key[n]=9;
         n++;
void key_manage11()
         tab_key[n]=10;
         n++;
void key_manage12()
         tab_key[n]=11;
         n++;
void key_manage13()
         tab_key[n]=12;
         n++;
void key_manage14()
         tab_key[n]=13;
         n++;
void key_manage15()
         tab_key[n]=14;
         n++;
void key_manage16()
         tab_key[n]=15;
         n++;
void InitUART(void)
        SCON = 0x52;
        TMOD = 0x20;
        TCON = 0x69;
        TH1 = 0xf3;
void main()
                 lcd_init();
                 write_com(1);
                 TMOD = 0x20;                        // 定时器1工作于8位自动重载模式, 用于产生波特率
                TH1 = 0xFD;                                // 波特率9600
                TL1 = 0xFD;
                SCON = 0x50;                        // 设定串行口工作方式
                PCON &= 0xef;                        // 波特率不倍增
                TR1 = 1;                                // 启动定时器1
                IE = 0x0;                                // 禁止任何中断
                P2=0x7f;
                 while(1)
                         {                if(RI)                                                // 是否有数据到来
                        RI = 0;
                        tmp = SBUF;                                // 暂存接收到的数据
                        P0 = tmp;                                // 数据传送到P0口
                        send_char(tmp);                        // 回传接收到的数据
                                key_scan();
                                lcd_disp();
                                if(n>15)
                                                P3=        0x10;
                                                delay(10);
                                                P3=        0x18;
                                                delay(10);
                                                P3=        0x04;
                                                delay(10);
                                                P3=        0x08;
                                                delay(10);
                                                P3=        0x0c;
                                                delay(10);
                                                P3=        0x1c;
                                                delay(10);
                                                P3=        0x14;
                                                delay(10);
// 传送一个字符
        SBUF = txd;
        while(!TI);                                // 等特数据传送
        TI = 0;                                        // 清除数据传送标志
jiaxinhui 发表于 2013-4-11 21:36 | 显示全部楼层
你的代码好长啊,建议你直接说出你目前程序遇到什么问题,那问题与疑问明确点,这样大家才会帮你。这么长的代码,很少有人完整看下去的。
hlzhaowu 发表于 2013-4-11 22:46 | 显示全部楼层
楼上说得对啊,楼主想要把问题找出来也是一个个功能模块代码查啊
zd420325 发表于 2013-4-13 09:29 | 显示全部楼层
《程序调试黑宝书》
Breming 发表于 2013-4-13 12:29 | 显示全部楼层
搞单片机就是一步一步的调试,调试到某一步发现问题再拿出来讨论,这样一上来就贴代码,是没有都少人看了。。。
