请教c问题?
2382|11
 楼主| fengyeu 发表于 2007-11-21 21:04 | 显示全部楼层 |阅读模式
union                                          //程序标志位
unsigned int Register;
struct
 unsigned char bus_reset        :1;
 unsigned char suspend          :1;
 unsigned char remote_wakeup    :1;
 unsigned char int_isr          :1;
 unsigned char not_end          :1;
 unsigned char usb_idle         :1;
 unsigned char usb_busy         :1;
 unsigned char setup_packet_in  :1;
 unsigned char setup_packet_out :1;
 unsigned char set_addr         :1;
 unsigned char usb_endp0_in     :1;
 unsigned char usb_endp2_in     :1;
 unsigned char usb_endp2_out    :1;
}flags;
}usb_flags;
union                                         //中断寄存器
 unsigned char Register[2];
 struct
   unsigned char control_out_port  :1;
   unsigned char control_in_port   :1;
   unsigned char port_out_1        :1;
   unsigned char port_in_1         :1;
   unsigned char main_out_port     :1;
   unsigned char main_in_port      :1;
   unsigned char suspend_change    :1;
   unsigned char DMA_EOT           :1;
   unsigned char not_use           :7;
  }Interrupt;
}Interrupt_Register;
 楼主| fengyeu 发表于 2007-11-21 21:07 | 显示全部楼层
  :1;
  :1;
  :7
请问在这共用体里面的是什么作用啊!
不懂
 楼主| fengyeu 发表于 2007-11-21 21:08 | 显示全部楼层
还有unsigned char Register[2];
ayb_ice 发表于 2007-11-21 21:12 | 显示全部楼层
主要是位域
 楼主| fengyeu 发表于 2007-11-21 21:24 | 显示全部楼层
位域???
潭浩强的书里好象没有啊 ????
 楼主| fengyeu 发表于 2007-11-21 21:27 | 显示全部楼层
找到了,我是不懂的在翻书
我是不懂的在翻书,
而不是把书看完了在写。
不子知到这样学对不?????
 楼主| fengyeu 发表于 2007-11-21 21:29 | 显示全部楼层
那这句unsigned char Register[2];
做什么的???
平常人 发表于 2007-11-21 21:31 | 显示全部楼层
一个有2个unsigned char变量的数组
数组的名字为Register。
taoest 发表于 2007-11-22 11:01 | 显示全部楼层
C
c语言基础的书,先看完再说。
 楼主| fengyeu 发表于 2007-11-22 22:11 | 显示全部楼层
那请问是不是这样的Register(如下)
Interrupt_Register.Register[0]==
Interrupt_Register.Register[1]==
computer00 发表于 2007-11-22 22:57 | 显示全部楼层
我看这些代码怎么这么眼熟呢?好象是圈圈写的...
 楼主| fengyeu 发表于 2007-11-22 23:20 | 显示全部楼层
是的OO的
是的OO的
我用KEIL调了下知道了
C啊。。。。。。。。。。。。继续
