[STM8] stm8l ADC 转换问题
3541|1
 楼主| ljl885712 发表于 2013-4-18 16:42 | 显示全部楼层 |阅读模式
int mcu_ad_cov_sig(unsigned char ch_num)
  unsigned  int i;
  unsigned int  ad_result;
  CLK_PCKENR2 = CLK_PCKENR2 | 0X01;       //使能外设ADC的时钟,之后对ADC的寄存器操作有效
  ADC1_CR1 = 0X01;                        //开启AD模块电源,使用Sing mode;
  ADC1_CR2 = 0X02;                        //使用MCU系统时钟频率作ADC的时钟;
                                          //AD转换软启动;
                                          //AD采样时间24个系统时钟;
  ADC1_SQR1_DMAOFF = 1;                   //禁止DMA传输;
  switch (ch_num)
      case 0:{ADC1_SQR4 = 0X02; break;}      //测量充放电流值,in1
      case 1:{ADC1_SQR4 = 0X10; break;}      //测量BAT1,in4
      case 2:{ADC1_SQR4 = 0X20; break;}      //测量BAT2,in5
      case 3:{ADC1_SQR4 = 0X40; break;}      //测量BAT3,in6
      case 4:{ADC1_SQR3 = 0X04; break;}      //测量BAT4,in10
      case 5:{ADC1_SQR3 = 0X08; break;}      //测量BAT5,in11
      case 6:{ADC1_SQR3 = 0X10; break;}      //测量BAT6,in12
      case 7:{ADC1_SQR3 = 0X20; break;}      //测量BAT7,in13
      case 8:{ADC1_SQR3 = 0X40; break;}      //测量BAT8,in14
      case 9:{ADC1_SQR3 = 0X80; break;}      //测量BAT9,in15
      case 10:{ADC1_SQR2 = 0X01; break;}     //测量BAT10,in16
      case 11:{ADC1_SQR2 = 0X02; break;}     //测量BAT11,in17
      case 12:{ADC1_SQR2 = 0X04; break;}     //测量BAT12,in18
      case 13:{ADC1_SQR2 = 0X08; break;}     //测量BAT13,in19
      case 14:{ADC1_SQR2 = 0X10; break;}     //测量BAT14,in20
      case 15:{ADC1_SQR2 = 0X20; break;}     //测量BAT15,in21
      case 16:{ADC1_SQR2 = 0X40; break;}     //测量BAT16,in22
  ADC1_CR1_START = 1;                       //启动AD转换
  for(i=0;i<15;i++)                         //加入固定延时,等待AD转换完成
  {asm("nop");}
  ad_result = ADC1_DRH << 8 ;
  ad_result = ad_result + ADC1_DRL;         //读取AD转换值
  ADC1_SQR4 = 0x00;
  ADC1_SQR3 = 0x00;
  ADC1_SQR2 = 0x00;                         //AD转换完成后,清除AD选中的通道
  ADC1_CR1 = 0x00;                          //关闭AD模块电源
  CLK_PCKENR2 = CLK_PCKENR2 & 0xFE;         //关闭AD时钟
  return  ad_result;                        //返回AD值
void  main()
  for(i=0;i<count;i++)
    ad[i] = mcu_ad_cov_sig(ch_num);
    sum = sum + ad[i];
    for(j=0;j<25000;j++)
     asm("nop");
     asm("nop");
在MAIN()函数中,如果我不加25000这个 NOP 延时,8次的采样值只有第一个是正确的,其余7个值都是一致便小,而且值的大小都很接近
难道STM8L的  AD转换需要加这么长的延时么????
望知情人告知如何做????  谢谢
cjhk 发表于 2013-4-18 18:43 | 显示全部楼层
不是很了解   楼主  帮你顶一个   希望有高手能够解决   顶起来
