MA84G564键盘中断问题
1920|0
 楼主| toney20110101 发表于 2013-4-21 14:30 | 显示全部楼层 |阅读模式
请帮忙看一下,下面的程序为啥板子通电后没按任何按键的情况下,蜂鸣器器就会叫。
#include "REG_MA84G564.H"
#define    T0_1MSL         0x18                  // ( 65536 - 1000 )%256 in 12Mhz
#define    T0_1MSH         0xFC                  // ( 65536 - 1000 )/256 in 12Mhz
unsigned char T0Cnt;
void INT_TIMER0(void) interrupt 1 using 1        // Timer0 Interrupt
        WDTCR = 0x17;                                 // Reset Watch Dog Timer
        TR0 = 0;                                   // Disable Timer0
        if ( T0Cnt )
                T0Cnt--;
                TL0 = T0_1MSL;
                TH0 = T0_1MSH;
                TR0 = 1;                               // Enable Timer0
void delayms( unsigned char X )
        T0Cnt = X;                                   // X*1ms = Xms
        TL0 = T0_1MSL;
        TH0 = T0_1MSH;
        while( T0Cnt );
void bell(void)
        P24=0;
        delayms(200);
        P24=1;
        delayms(100);
        P24=0;
        delayms(50);
        P24=1;
        delayms(100);
void INT_KB(void) interrupt 13
        bell();
void main(void)
        TMOD = 0x11;                                 // Set Timer0/1 in Mode1/2 ( 16/8 bit )
  TR0 = 0;                                     // Desable Timer0
  ET0 = 1;
        EIE1 |= 0x20;
        EIP1H |= 0x20;
        EIP1L |= 0x20;
        KBPATN = 0xff;
  KBCON = 0x03;
  KBMASK = 0xff;                               // Will Disable KP Interrupt
        AUXR1 &= 0x3f;
        EA=1;
        while(1);
