launchpad c2000 hrpwm
2593|3
 楼主| xdlicheng 发表于 2013-4-23 10:19 | 显示全部楼层 |阅读模式
谁能帮忙解释一下这段程序了!做什么用的啊?
while (update ==1)
        for(DutyFine =1; DutyFine <256 ;DutyFine ++)
            // Example, write to the HRPWM extension of CMPA
            PWM_setCmpAHr(myPwm1, DutyFine << 8);
            PWM_setCmpAHr(myPwm2, DutyFine << 8);
            // Example, 16-bit write to CMPAHR
            PWM_setCmpAHr(myPwm3, DutyFine << 8);
            PWM_setCmpAHr(myPwm4, DutyFine << 8);
            for (i=0;i<10000;i++){                          // Dummy delay between MEP changes
pmp 发表于 2013-4-24 00:11 | 显示全部楼层
目测设置pwm周期
threetigher 发表于 2013-9-2 21:16 | 显示全部楼层
目测设置pwm周期
wgdxiaoqiang 发表于 2013-12-16 16:22 | 显示全部楼层
应该就是这段程序:
        EPwm1Regs.CMPA.half.CMPAHR = DutyFine << 8;     // Left shift by 8 to write into MSB bits
        EPwm2Regs.CMPA.half.CMPAHR = DutyFine << 8;     // Left shift by 8 to write into MSB bits
        // Example, 32-bit write to CMPA:CMPAHR
        EPwm3Regs.CMPA.all = ((Uint32)EPwm3Regs.CMPA.half.CMPA << 16) + (DutyFine << 8);
        EPwm4Regs.CMPA.all = ((Uint32)EPwm4Regs.CMPA.half.CMPA << 16) + (DutyFine << 8);
        for (i=0;i<10000;i++){}                         // Dummy delay between MEP changes
但是不确定具体的作用,更新CMPAHR?,mep的值在哪里设置?还是系统时钟对应确定的mep,如60MHZ下180ps?
