Registers starts from the address 0x01800000h. Each block is allocated 1Kbytes in the format of Memory Mapped I/O.
寄存器开始地址是:0x01800000h 是这个意思吗?
Each block is allocated 1Kbytes in the format of Memory Mapped I/O. 每个区块分配1kbytes在格式的**体映射的I / O
这个具体是什么意思啊?
谢谢! |
