在这个函数里面发送数据时可以,但把发送程序写在主函数里就没用,
* Function Name : EP1_OUT_Callback.
* Description : EP1 OUT Callback Routine.
* Input : None.
* Output : None.
* Return : None.
void EP1_OUT_Callback(void)
BitAction Led_State;
PrevXferComplete = 1;
/* Read received data (2 bytes) */
USB_SIL_Read(EP1_OUT, Receive_Buffer);
/* write received data (2 bytes) */
send_Buffer[0] = 0X07;
Write the descriptor through the endpoint */
USB_SIL_Write(EP1_IN, (uint8_t*) send_Buffer, 2);
SetEPTxValid(ENDP1);
报告描述符为
const uint8_t CustomHID_ReportDescriptor[CUSTOMHID_SIZ_REPORT_DESC] =
0x06, 0xFF, 0x00, /* USAGE_PAGE (Vendor Page: 0xFF00) */
0x09, 0x01, /* USAGE (Demo Kit) */
0xa1, 0x01, /* COLLECTION (Application) */
/* 6 */
/* Led 1 */
0x85, 0x01, /* REPORT_ID (1) */
0x09, 0x01, /* USAGE (LED 1) */
0x15, 0x00, /* LOGICAL_MINIMUM (0) */
0x25, 0x01, /* LOGICAL_MAXIMUM (1) */
0x75, 0x08, /* REPORT_SIZE (8) */
0x95, 0x01, /* REPORT_COUNT (1) */
0xB1, 0x82, /* FEATURE (Data,Var,Abs,Vol) */
0x91, 0x82, /* OUTPUT (Data,Var,Abs,Vol) */
/* 26 */
/* Led 2 */
0x85, 0x02, /* REPORT_ID 2 */
0x09, 0x02, /* USAGE (LED 2) */
0x85, 0x02, /* REPORT_ID (2) */
/* 46 */
/* Led 3 */
0x85, 0x03, /* REPORT_ID (3) */
0x09, 0x03, /* USAGE (LED 3) */
/* 66 */
/* Led 4 */
0x85, 0x04, /* REPORT_ID 4) */
0x09, 0x04, /* USAGE (LED 4) */
0x85, 0x04, /* REPORT_ID (4) */
/* 86 */
/* key Push Button */
0x85, 0x05, /* REPORT_ID (5) */
0x09, 0x05, /* USAGE (Push Button) */
0x75, 0x01, /* REPORT_SIZE (1) */
0x81, 0x82, /* INPUT (Data,Var,Abs,Vol) */
0xb1, 0x82, /* FEATURE (Data,Var,Abs,Vol) */
0x75, 0x07, /* REPORT_SIZE (7) */
0x81, 0x83, /* INPUT (Cnst,Var,Abs,Vol) */
0x85, 0x05, /* REPORT_ID (2) */
0xb1, 0x83, /* FEATURE (Cnst,Var,Abs,Vol) */
/* 114 */
/* Tamper Push Button */
0x85, 0x06, /* REPORT_ID (6) */
0x09, 0x06, /* USAGE (Tamper Push Button) */
/* 142 */
/* ADC IN */
0x85, 0x07, /* REPORT_ID (7) */
0x09, 0x07, /* USAGE (ADC IN) */
0x26, 0xff, 0x00, /* LOGICAL_MAXIMUM (255) */
0x09, 0x07, /* USAGE (ADC in) */
/* 161 */
0xc0 /* END_COLLECTION */
}; /* CustomHID_ReportDescriptor */
请教 |
