这是回调函数EP1_IN_Callback与EP2_OUT_Callback内的程序,我认为在回调函数里面也是要改,我想实现数据流的发送,可是这里面的内容我不能理解,忘大神指点
* Function Name : Mass_Storage_In
* Description : Mass Storage IN transfer.
* Input : None.
* Output : None.
* Return : None.
//设备->USB
void Mass_Storage_In (void)
USB_STATUS_REG|=0X10;//标记轮询
switch (Bot_State)
case BOT_CSW_Send:
case BOT_ERROR:
Bot_State = BOT_IDLE;
SetEPRxStatus(ENDP2, EP_RX_VALID);/* enable the Endpoint to recive the next cmd*/
break;
case BOT_DATA_IN: //USB从设备读数据
switch (CBW.CB[0])
case SCSI_READ10:
USB_STATUS_REG|=0X02;//标记正在读数据
SCSI_Read10_Cmd(CBW.bLUN , SCSI_LBA , SCSI_BlkLen);
break;
break;
case BOT_DATA_IN_LAST:
Set_CSW (CSW_CMD_PASSED, SEND_CSW_ENABLE);
break;
default:
break;
* Function Name : Mass_Storage_Out
* Description : Mass Storage OUT transfer.
* Input : None.
* Output : None.
* Return : None.
//USB->设备
void Mass_Storage_Out (void)
u8 CMD;
CMD = CBW.CB[0];
Data_Len = GetEPRxCount(ENDP2);
PMAToUserBufferCopy(Bulk_Data_Buff, ENDP2_RXADDR, Data_Len);
switch (Bot_State)
case BOT_IDLE:
CBW_Decode();
break;
case BOT_DATA_OUT://USB发送数据到设备
if (CMD == SCSI_WRITE10)
USB_STATUS_REG|=0X01;//标记正在写数据
SCSI_Write10_Cmd(CBW.bLUN , SCSI_LBA , SCSI_BlkLen);
break;
Bot_Abort(DIR_OUT);
Set_Scsi_Sense_Data(CBW.bLUN, ILLEGAL_REQUEST, INVALID_FIELED_IN_COMMAND);
Set_CSW (CSW_PHASE_ERROR, SEND_CSW_DISABLE);
break;
default:
Bot_Abort(BOTH_DIR);
break;
