推销arm芯片!
2725|6
 楼主| jt4117 发表于 2007-1-15 14:08 | 显示全部楼层 |阅读模式
一款开发读卡器方案很适合的ARM芯片。有兴趣的留下脚印啊!!
32-bit ARM7TDMI RISC static CMOS CPU core (Running up to 60 MHz)
8Kbytes combined instruction/data cache
Memory management unit
Supports Little-endian operating system
8Kbytes SRAM for internal buffer memory
2Kbytes Boot ROM
On-chip peripherals with individual power-down:
 Memory controller for ROM(x8,16), Flash(x8,16), SRAM(x8,16), SDRAM(x16)
 5-State Power management unit (Sofrware selectable Clock Frequency)
 Interrupt Controller
 LCD Controller for color and mono STN
 USB 1.1(slave)
 Two Smart Card Interface (UART 0,1)
 Two UART (UART 2,3)
 One SIR support UART (UART4)
 One Modem support UART (UART5)
 Four 16-bit Timer Channels (with Output Port)
 Two 16-bit PWM Channels (with Output Port)
 Programmable WatchDog Timer with On-chip Oscillator
 Real-time clock (32.768kHz oscillator) with separated Vcc
 Matrix Keyboard control interface (6x6)
 97 Programmable GPIO
 One 2-Wire Serial Bus Interface
 2-Channel Master/Slave SSI (SPI)
 SMC Card Interface
 On-chip 3-Channel 10-bit ADC
JTAG debug interface and boundary scan
0.35um CMOS Process
3.3V supply voltage
208-pin LQFP / CABGA package
Low power consumption
 楼主| jt4117 发表于 2007-1-15 14:13 | 显示全部楼层
价格合理,非代理商推销。原厂推广!
 楼主| jt4117 发表于 2007-1-15 14:26 | 显示全部楼层
自己顶!
shiyang800 发表于 2007-1-16 14:33 | 显示全部楼层
哪个公司的产品啊,发个资料看看 谢谢!
E_mail:  shiyang@star-net.cn
lxg163com 发表于 2007-1-16 15:08 | 显示全部楼层
建议
能附带一些资料看看吗?
win2000_li 发表于 2007-1-16 16:34 | 显示全部楼层
公司网战呢?????
 楼主| jt4117 发表于 2007-1-17 13:23 | 显示全部楼层
abov semiconductor
公司网址:www.abov.co.kr
abov semiconductor .co.,Ltd(原韩国现代)
