STM32 PD12产生PWM波问题
3281|4
 楼主| ranguangxu 发表于 2013-4-27 20:42 | 显示全部楼层 |阅读模式
int main(void)
  u16 CCR1_Val = 0x7fff;
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD , ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_PinRemapConfig(GPIO_Remap_TIM4 , ENABLE);
  TIM_DeInit(TIM4);
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM4,&TIM_OCInitStructure);
  TIM_Cmd(TIM4,ENABLE);
大家好,我主要是想用PD12产生PWM波,由于PD12默认是没有功能的,所以要通过映射的方式,但是却产生不出来,帮助一下了哦:'(
jiaxinhui 发表于 2013-4-27 22:12 | 显示全部楼层
IO所在的总线,复用功能时钟开启了吗  还有就是映射使能了吗?
 楼主| ranguangxu 发表于 2013-4-28 18:51 | 显示全部楼层
GPIO_PinRemapConfig(GPIO_Remap_TIM4 , ENABLE); 这个是不是映射时能吗? AFIO没开
wulinz 发表于 2013-4-29 09:57 | 显示全部楼层
应该还需要loadARR使能
 楼主| ranguangxu 发表于 2013-4-29 15:27 | 显示全部楼层
应该还需要loadARR使能
TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable); 这个? 我后来加上去了 还是不行
