STM32F207使用FSMC的问题
5622|3
 楼主| ningzb 发表于 2013-4-28 11:10 | 显示全部楼层 |阅读模式
1.使用的芯片STM32F207IET6
2.用FSMC连接SRAM和液晶模块(LCM),都是采用8位的数据接口,
   SRAM的片选和CPU的153引脚即PG10(FSMC_NE3)相连接,LCM的片选 和CPU的154引脚即PG11(FSMC_NE4)相连接
初始化代码如下:
FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
        FSMC_NORSRAMTimingInitTypeDef  p;
        RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOG, ENABLE);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1  | GPIO_Pin_4  | GPIO_Pin_5  | GPIO_Pin_11 |
                                                        GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource0 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource1 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource2 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource3 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource4 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource5 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource12 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource13 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource14 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource15 , GPIO_AF_FSMC);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_1  | GPIO_Pin_2  | GPIO_Pin_3  |
                                                        GPIO_Pin_4  | GPIO_Pin_5  | GPIO_Pin_12 | GPIO_Pin_13 |
        GPIO_Init(GPIOF, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource0 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource1 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource2 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource3 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource4 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource5 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource10 , GPIO_AF_FSMC);
        GPIO_PinAFConfig(GPIOG, GPIO_PinSource11 , GPIO_AF_FSMC);
                                                        GPIO_Pin_4  | GPIO_Pin_5  |GPIO_Pin_10 |GPIO_Pin_11;
        GPIO_Init(GPIOG, &GPIO_InitStructure);
        /*-- FSMC Configuration ------------------------------------------------------*/
        p.FSMC_AddressSetupTime = 0x02;
        p.FSMC_AddressHoldTime = 2;
        p.FSMC_DataSetupTime = 0x5;
        p.FSMC_BusTurnAroundDuration = 0;
        p.FSMC_CLKDivision = 0;
        p.FSMC_DataLatency = 0;
        p.FSMC_AccessMode = FSMC_AccessMode_A;
        FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;
        FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
        FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_PSRAM;
        FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
        FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
        FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
        FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
        FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
        FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
        FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
        FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
        /*!< Enable FSMC Bank1_SRAM3 Bank */
        FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE);
p.FSMC_AddressSetupTime = 1;
        p.FSMC_AddressHoldTime = 0;
        p.FSMC_DataSetupTime = 9;
        FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
        /*!< Enable FSMC Bank1_SRAM4 Bank */
        FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
3.遇到的问题:SRAM的地址是从0x68000000开始,进行读写测试正常;
    LCM的其实地址是0x6C000000,
   对0x6C000000开始的地址进行读写时,用示波器测试LCM的片选信号,一直是高电平,没有任何变化
请问可能是什么原因引起的?
已经用万用表测试了LCM的片选和CPU连接正常,没有对地和电源短路
先谢谢了
IJK 发表于 2013-4-28 13:42 | 显示全部楼层
建议:
1) 把PG11设置成GPIO,并输出高电平和低电平,看是否正常
2) 把FSMC_Bank1_NORSRAM4的时序设置得慢点,看是否正常
 楼主| ningzb 发表于 2013-4-28 15:59 | 显示全部楼层
谢谢,基本找到问题了,应该是PG12,而不是PG11,等待进一步确认
 楼主| ningzb 发表于 2013-4-28 17:25 | 显示全部楼层
已经解决,就是硬件连接的问题,NE4应该连接到PG12上
