MicroBlaze MCS –基于 MicroBlaze 的微控制器设计现已在 ISE 13.4 中
2150|2
 楼主| lxAPP 发表于 2013-5-2 21:40 | 显示全部楼层 |阅读模式
作为 LogiCORE™ IP 核产品的新增成员,MicroBlaze 微控制器系统 (MCS) 可以为 Xilinx 客户提供交钥匙微控制器解决方案,并且已经包含在 ISE 13.4 逻辑版本和 WebPACK 中。基于 MicroBlaze 的 MCS 无需嵌入式版本或 XPS 即可通过易于配置的 GUI 提供轻型微控制器系统(包括外设)。
New in ISE® 13.4, Xilinx introduces MicroBlaze™ Micro Controller System (MCS). MicroBlaze MCS is a complete standalone processor system that is delivered through ISE CORE Generator, intended for lighter-weight controller applications. MicroBlaze MCS delivers a self-contained soft-processor microcontroller with no need for the Embedded Design Kit (EDK), IDS Embedded Edition, or Xilinx Processor Design System (XPS). Now IDS Logic Edition users can configure and utilize a standalone processor-based system.
MicroBlaze MCS is a tightly integrated system, including the microblaze processor, local memory for program
and data storage, a coupled IO module, and a standard set of peripherals. The MicroBlaze processor included in the MCS has a fixed configuration, optimized for minimal area.
MicroBlaze MCS is added as a source in Project Navigator or PlanAhead through CORE Generator and then configured using the MicroBlaze MCS configuration wizard aiding the designer in configuring any needed peripherals and other system options.
MicroBlaze MCS is based on MicroBlaze, the industry leading soft-processing FPGA solution from Xilinx, and delivers the basic key features embedded designers need for a lighter microcontroller system, without the overhead of running an embedded design system. Compare MicroBlaze and MicroBlaze MCS to find out which system is right for you:
MicroBlaze MCS
MicroBlaze
Availability
Included in IDS Logic Edition (beginning in 13.4 release)
Included in IDS Embedded Edition
Web Edition Available
Yes
No
Cost
Free
Free
Configurable
Peripherals and I/O, processor configuration is fixed
Up to 70 different configuration options
Pipeline
3-stage
3-stage or 5-stage selectable
Memory
4kB-64kB Local memory only (Block RAM)
Local or External through virtual memory management up to 4GB
Streaming Ports
No
Yes
Debug
Yes through MicroBlaze Debug Module (MDM)
Peripherals
UART, interrupt controller, 4 programmable interval timers, 4 fixed interval times, 4 general purpose outputs, 4 general purpose inputs, I/O bus
Multiple peripherals are supported through the free Embedded Edition IP catalog
AXI-4 bus connections
No
Yes
Software support
Xilinx Software Development Kit (SDK) or other Eclipse-based IDE
GoldSunMonkey 发表于 2013-5-3 22:43 | 显示全部楼层
新鲜的玩意啊
xjsxjtu 发表于 2013-5-4 23:14 | 显示全部楼层
这个工具不错啊。还免费。哈哈
