为什么总返回-1有源码?
1367|3
 楼主| huangfeng33 发表于 2013-5-8 16:02 | 显示全部楼层 |阅读模式
BOOL InitNet(CString m_strGXCJPath)
DWORD SocketMode = 0;
int nPort;
CString m_strCfgInspect;
char cIPAddr[20]="\0";
sockaddr_in addr;
int ret;
m_strCfgInspect= m_strGXCJPath + "\\DPSet.ini";
nPort = GetPrivateProfileInt("ItemDP","Port",-1,m_strCfgInspect);  //端口
GetPrivateProfileString("ItemDP","IPAddr",(LPCTSTR)"",cIPAddr,20,m_strCfgInspect); //IP 地址
WSADATA data; //定义WSADATA结构体对象
  WSAStartup(MAKEWORD(2,2),&data) ;
LocSocket=::socket(AF_INET,SOCK_STREAM,0);
:: WSAAsyncSelect(LocSocket,this->m_hWnd,WM_SOCK, FD_READ|FD_CONNECT);
addr.sin_family=AF_INET;
    addr.sin_addr.S_un.S_addr=inet_addr(cIPAddr);
    addr.sin_port=ntohs(nPort);
ret = connect(LocSocket,(sockaddr*)&addr,sizeof(addr));
if(ret)  //为什么总返回-1 ???/
return TRUE;
return FALSE;
jxmzzr 发表于 2013-5-8 16:35 | 显示全部楼层
调用WSAGetLastError()看看返回值,再查msdn,就知道是啥问题了
hawksabre 发表于 2013-5-8 18:29 | 显示全部楼层
单步调试   看看   是哪个函数出错了   呵呵    错误还是很明显的
拿起书本 发表于 2013-5-9 15:34 | 显示全部楼层
SOCKET_ERROR
a specific error code can be retrieved by calling WSAGetLastError
