菜鸟请教各位:electr01在protel仿真中出错该怎么办呢?
2819|1
 楼主| 浪漫火星 发表于 2007-7-11 09:47 | 显示全部楼层 |阅读模式
刚用protel,想把电路图仿真一下的,仿真库中没有有极性电容怎么办呢?先谢谢了!!<br />&nbsp;用了miscellaneous&nbsp;devices库中的electr01,错误如下:<br />C1&nbsp;Error:&nbsp;Pin&nbsp;order&nbsp;data&nbsp;(PINS=1:[&ltpins&gt])&nbsp;not&nbsp;in&nbsp;READ&nbsp;ONLY&nbsp;field&nbsp;4.&nbsp;Pins&nbsp;sorted&nbsp;by&nbsp;pin-name.<br />C1&nbsp;Error:&nbsp;Part&nbsp;type&nbsp;must&nbsp;be&nbsp;entered&nbsp;in&nbsp;READ&nbsp;ONLY&nbsp;field&nbsp;1:&nbsp;type=&ltpart&nbsp;type&gt(&ltspice&nbsp;prefix&gt)<br />C1&nbsp;Error:&nbsp;Netlist&nbsp;data&nbsp;must&nbsp;be&nbsp;entered&nbsp;in&nbsp;READ&nbsp;ONLY&nbsp;field&nbsp;5:&nbsp;netlist=&ltnetlist&nbsp;data&gt
 楼主| 浪漫火星 发表于 2007-7-16 14:23 | 显示全部楼层
没人理哦
唉~~~~~~~~~~~是不是我问的太菜了啊
