[产品供应] 新唐Core-M0 /ARM7/ARM9/SoC
2086|1
 楼主| jingchen911 发表于 2013-5-16 15:26 | 显示全部楼层 |阅读模式
Part No.        Flash        SRAM        I/O        Timer        Connectivity                                PWM        12-bit        RTC        EBI        ISP        PDMA        ISO-7816-3        Touch        IRC        Package
        ADC                        ICP                        Key        10MHz
                                        UART        SPI        I2C        USB        12MHz
NANO120LC2BN        32K        8K        34        4x32-bit        4        3        2        1        4        7        v        -        v        8        2        4        v        LQFP48
NANO120LD2BN        64K        8K        34        4x32-bit        4        3        2        1        4        7        v        -        v        8        2        4        v        LQFP48
NANO120LD3BN        64K        16K        34        4x32-bit        4        3        2        1        4        7        v        -        v        8        2        4        v        LQFP48
NANO120LE3BN        128K        16K        34        4x32-bit        4        3        2        1        4        7        v        -        v        8        2        4        v        LQFP48
NANO120SC2BN        32K        8K        48        4x32-bit        5        3        2        1        8        7        v        -        v        8        3        8        v        LQFP64*
NANO120SD2BN        64K        8K        48        4x32-bit        5        3        2        1        8        7        v        -        v        8        3        8        v        LQFP64*
NANO120SD3BN        64K        16K        48        4x32-bit        5        3        2        1        8        7        v        -        v        8        3        8        v        LQFP64*
NANO120SE3BN        128K        16K        48        4x32-bit        5        3        2        1        8        7        v        -        v        8        3        8        v        LQFP64*
NANO120KC2BN        32K        8K        86        4x32-bit        5        3        2        1        8        8        v        v        v        8        3        16        v        LQFP128**
NANO120KD2BN        64K        8K        86        4x32-bit        5        3        2        1        8        8        v        v        v        8        3        16        v        LQFP128**
NANO120KD3BN        64K        16K        86        4x32-bit        5        3        2        1        8        8        v        v        v        8        3        16        v        LQFP128**
NANO120KE3BN        128K        16K        86        4x32-bit        5        3        2        1        8        8        v        v        v        8        3        16        v        LQFP128**
*Status: P= Mass Production, S=Samples, UD=Under Development, UD (Time)= Under Development(Ready Time), EOL=End of life.
*LQFP64: 7 x 7mm
**LQFP128: 14 x 14mm
NUC ARM
Part No.        Core                                         Memory                         Storage                         MAC         USB                                 Video                 GFX         LCD         Timer                 Analog                                         Peripheral        Power                         Package                 Status**
        ADC (10-bit)
        CPU Speed (MHz)         I Cache (KB)         D Cache (KB)         SRAM (KB)         Security against piracy         SDRAM         NOR Flash         SPI Flash, No. of I/O Pins         NAND Flash, No. of ECC bits         ATAPI         SD / SDIO         Ethernet 10/100 MAC         USB 1.1 Host (12 Mbps)         USB 2.0 Host (480 Mbps)         USB 2.0 FS Device         USB 2.0 HS Device         JPEG Codec         MP4 Codec         2D Graphics         LCD Control I/F         Real-Time Clock (RTC)         PWM         No. of Channels         Speed (Samples per second)         Touch Screen Controller         16-bit DAC Channels         LVD/LVR         JTAG         External Bus Interface         GPIO (Max)         UART         I2C         SPI         KPI         PS2         I2S/AC97         YUV Sensor Interface         PCI Master         Core Voltage (V)         I/O Voltage (V)         Built-in LDO         Operating Temperature*         Package
ARM7 Family
NUC501A        80        -         -         32        Y         -         -         2        -         -         -         -         -         -         1        -         -         -         -         -         Y         4        8        400K         -         1        Y         Y         -         26        1        1        2        -         -         -         -         -         1.8        3.3        Y         E         LQFP48         P
NUC501B        37        2        LQFP64
NUC710A        80        4        4        -         -         Y         Y         1        -         -         1        1        2        -         1        -         -         -         -         Y         Y         4        -         -         -         -         -         Y         Y         71        4        2        1        Y         1        1        -         -         1.8        3.3        -         I         LQFP176         P
NUC740A        80        8        2        -         -         Y         Y         -         -         -         -         2        1        -         -         -         -         -         -         -         -         -         -         -         -         -         -         Y         Y         21        1        -         -         -         -         -         -         -         1.8        3.3        -         C         LQFP176         P
NUC745A        80        4        4        -         -         Y         Y         1        -         -         -         1        2        -         1        -         -         -         -         -         -         4        -         -         -         -         -         Y         Y         31        4        2        1        Y         1        1        -         -         1.8        3.3        -         C         LQFP128         P
ARM9 Family
NUC910A        200        8        8        -         -         Y         Y         1        4        Y         2        1        -         2        -         1        -         -         Y         Y         Y         4        8        300K         Y         -         Y         Y         Y         92        5        2        1        Y         2        1        -         -         1.8        3.3        -         I         PBGA324         P
NUC920A        200        8        8        -         -         Y         Y         1        -         Y         1        1        -         2        -         1        -         -         -         -         Y         4        8        300K         Y         -         Y         Y         Y         92        3        2        1        Y         2        1        -         3        1.8        3.3        -         I         PBGA324         P
NUC945A        200        8        8        -         -         Y         Y         -         -         -         1        1        -         1        -         1        -         -         -         -         -         -         -         -         -         -         -         -         Y         34        1        -         -         -         -         -         -         -         1.8        3.3        -         C         LQFP128         P
NUC950A        200        8        8        -         -         Y         Y         1        4        -         1        1        -         2        -         1        -         -         Y         Y         -         4        -         -         -         -         -         Y         Y         52        3        2        1        Y         -         1        -         -         1.8        3.3        -         I***        LQFP216         P
NUC960A        200        8        8        -         -         Y         Y         1        -         -         -         1        -         2        -         1        -         -         -         -         -         -         -         -         -         -         -         Y         Y         51        3        2        1        -         -         -         -         2        1.8        3.3        -         I***        LQFP216         P
陈先生
公司:深圳市威凯特科技有限公司
电话: +86-755-61392309-805
手机:13728700073
传真: +86-755-61392390
网址:w-w-w.victor-ic.c-n
地址:深圳市福田区振中路鼎诚国际大厦2508室
qizhemayikanhai 发表于 2014-5-21 21:12 | 显示全部楼层
深圳顺易捷科技有限公司网上ERP系统计算价格和下单,方便快捷
(单双面PCB板12小时和24小时,多层板72小时加急打样)
1. 单双面板 5*5CM以内的,pcb打样50元/款;
2. 单双面板10*10CM以内的,pcb打样100元/款;
3. 多层板 10*10CM以内的,pcb打样500元/款。
以上报价工艺为:FR-4,绿油白字,有铅喷锡工艺,数量为10片内,材料均采用建滔KB顶级板材,样板免费全测!
4.单面纸板(94V0)样板,半玻纤,铝基板 小批量生产
热线:15889514284  QQ:2263279526
工厂地址:深圳市龙岗区坪地街道年丰社区友谊北路11号
