| 我有个原理图是protel转过去的,转时没有错误。<br />可是在生成PCB时却出现了下面的提示:<br />*Not valid pin name for part type B15<br />JP1.1 C1.2 P1.B15 P1.B3 P1.B17  (这些是连到GND的)<br />这是怎么一回事呢?<br /><br />部分错误提示:<br />Part name already used J5<br />J5      HEADER_7X2@HDR2X7<br />Part name already used C190<br />C190    CAP_NP@0603<br />Part name already used C191<br />C191    CAP_NP@0603<br />*Not valid pin name for part type B15<br />JP1.1 C1.2 P1.B15 P1.B3 P1.B17 <br />*Not valid pin name for part type B22<br />P1.B22 P1.B28 P1.B34 P1.B38 P1.B46 <br />*Not valid pin name for part type B49<br />P1.B49 P1.B57 P1.A18 P1.A24 P1.A30 <br />*Not valid pin name for part type A35<br />P1.A35 P1.A37 P1.A42 P1.A48 P1.A56 <br />*Not valid pin name for part type B9<br />C22.2 P1.B9 P1.B11 C23.1 C3.2 <br />*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MUTEC<br />*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal GPIO57<br />*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal AO_SD3<br />*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal AO_SD2<br />*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal AO_SD1  |
