跪求大神帮忙移植下程序
4210|19
 楼主| ahscchjch 发表于 2013-5-16 20:31 | 显示全部楼层 |阅读模式
本人毕设:gps信息采集与完好性监测系统设计,现有一51单片机程序,老师要求用msp430f149做,跪求大神帮忙移植下。
#include <reg52.h>
#include <absacc.h>
#include <intrins.h>
#include <header.h>
#include <math.h>
#define D_PORT        P0
sbit RS                =P2^0;
sbit RW                =P2^1;
sbit E                =P2^2;
#define         LCD_BUS         P0
#define LCD_COMMAND                        0
#define LCD_DATA                        1
unsigned char data GPS_buffer[60];
unsigned char  xdata GPS_Data_num=0;
unsigned char data GPS_utc_buffer[7];
unsigned char  xdata GPS_utc_len=0;
unsigned char xdata GPGRS_datalen[12];
unsigned char  xdata comma_number= 0;
unsigned char  xdata sv_status_flag=0;
unsigned char  data display_square_error[6]=0;
GPS_DATA_SH xdata posdata_shu;
void wait_free()
        unsigned char retb;
        do{
         D_PORT=0xff;
         E=1;
         retb=D_PORT;
        }while((retb&0x80)!=0);
void write_comm(unsigned char cmd_dat,bit cd)
        wait_free();
         if(cd)RS=1;
         else RS=0;
         RW=0;
         E=1;
         D_PORT=cmd_dat;
void LCD_SetInput(unsigned char InputMode)
        write_comm( 0x04|InputMode,0);
void LCD_SetDisplay(unsigned char DisplayMode)
        write_comm(0x08|DisplayMode,0);
void delay()
        unsigned int i,k;
        for(i=0;i<100;i++)
        for(k=0;k<100;k++);
void GotoXY(unsigned char x, unsigned char y)
        if(y==0)
                write_comm(0x80|x,LCD_COMMAND);
        if(y==1)
                write_comm(0x90|x,LCD_COMMAND);
void Print(unsigned char *str,unsigned char len)
   unsigned char i;
        for(i=0;i<len;i++)
               write_comm(*str++,1);
void LCD_ShowString(unsigned char line, unsigned char col, unsigned char *str,unsigned char len)
   GotoXY(col,line);
   Print(str,len);
void seria0() interrupt 4 using 2
    unsigned char data  RcvChar;
        unsigned char data dataHeader[6]="$GPGRS";
        if(RI)
          RI = 0 ;
                 RcvChar=SBUF;
            if(!posdata_shu.ful)
                         if(posdata_shu.check >=6  )
               if(RcvChar!=0x0a)
                                {        P1=0xf8;
                                                *(posdata_shu.buf+posdata_shu.off) = RcvChar;
                                                posdata_shu.off ++;
                else
                                        P1=0xf8;
                                                posdata_shu.ful = 1;
                                                posdata_shu.val = 1;
                                                posdata_shu.check = 0;
           else
                        if(*(dataHeader+posdata_shu.check) == RcvChar)
                                            {        posdata_shu.check++;
                                        else
                                            posdata_shu.check= 0;
                                            posdata_shu.off = 0 ;
                        else
void sv_status(unsigned char sv_number,float sv_sseerror)
  unsigned char sv_status_temp;
  switch(sv_number)
    case 5:
              if(sv_sseerror>31.960)
                   sv_status_temp=0x55;
                  else
                   sv_status_temp=0xaa;
                  break;
     case 6:
              if(sv_sseerror>24.088)
                  else
                   break;
         case 7:
              if(sv_sseerror>20.612)
                  else
                   break;
         case 8:
              if(sv_sseerror>18.551)
                  else
                   break;
         case 9:
              if(sv_sseerror>17.153)
                  else
                   break;
         case 10:
              if(sv_sseerror>16.125)
     case 11:
              if(sv_sseerror>15.331)
                  else
                   break;
          case 12:
              if(sv_sseerror>14.693)
                   break;
  sv_status_flag=sv_status_temp;
unsigned char *get_in_gps(unsigned char *paddr,unsigned char n)
        unsigned char *return_p;
        unsigned char i=0;
        return_p = paddr;
        while(1)
                if(*return_p == ',')
                        i++;
                return_p++;
                if(i == n)
                        break;
        return return_p;
unsigned char convertdata(unsigned char ch)
        if((ch>=0x30) &&(ch<=0x39))
                return (ch-0x30);
        if((ch>=0x41) &&(ch<=0x5a))
                return (ch-0x41+0x0a);
        if((ch>=0x61)&&(ch<=0x7a))
                return(ch-0x61+0x0a);
        return 0;
char GPS_Data_verify(unsigned char *paddr,unsigned char len)
        unsigned char comma = 0;
        unsigned char i;
        unsigned char index= 0;
        unsigned char index1= 0;
    unsigned char hour;
        unsigned char *pdat;
        unsigned char crc = 0x4b;
        unsigned char temp1;
        unsigned char temp2;
        unsigned char *pdat_buffer;
        pdat_buffer=paddr;
   for(i=0;i<len;i++)
           temp1=*pdat_buffer;
           temp2=*(pdat_buffer+1);
                if((*pdat_buffer ==',')&&(*(pdat_buffer+1)!=','))
                 comma_number++;
                 pdat_buffer++;
        comma_number=comma_number-3;
        pdat = get_in_gps(paddr, 1);
        for(i=0;i<6;i++)
                GPS_utc_buffer[index1++] = *(pdat+i);
                GPS_utc_len++;
        hour = (*pdat-0x30)*10+*(pdat+1)-0x30;
        hour +=8;
        hour %=24;
        *pdat = hour/10+0x30;
        *(pdat+1) = hour%10+0x30;
        for(i=0;i<6;i++)
                GPS_buffer[index++] = *(pdat+i);
    for(i=0;i<comma_number;i++)
      pdat = get_in_gps(paddr,(3+i));
         while(*pdat !=',')
           if(*pdat=='-')
                     pdat++;
           else
                GPS_buffer[index++] = *pdat;
                pdat++;
                GPGRS_datalen[i]++;
        GPS_Data_num=index;
        return index;
void gps_data_convert(void)
        unsigned char err_flag=0;
        unsigned char i=0;
    unsigned char index=0;
        float range_error[12];
        float squre_error=0;
        float sse_error=0;
    float squre_error_yushu=0;
        unsigned char squre_integer=0;
        unsigned char squre_integer_high=0;
    unsigned char squre_integer_low=0;
        unsigned int squre_temp=0;
        unsigned char squre_decimal_inte1=0;
    unsigned char squre_decimal_yushu=0;
        unsigned char squre_decimal_inte2=0;
        unsigned char squre_decimal_inte3=0;
        if(posdata_shu.val==1)
                        P1=0xfa;
                posdata_shu.val=0;
                  err_flag = GPS_Data_verify(posdata_shu.buf,posdata_shu.off);
                if(err_flag== -1)
                  P1=0xfb;
                        posdata_shu.ful = 0;
                        posdata_shu.off=0;
                        return;
                else if(err_flag ==0)
                {        P1=0xfc;;
                        posdata_shu.val = 0;
                        posdata_shu.off=0;
                        return;
             index=6;
                    if(GPGRS_datalen[i]==4)
                            range_error[i]=((convertdata(GPS_buffer[index]))*10+convertdata(GPS_buffer[index+1])+(convertdata(GPS_buffer[index+3]))*0.1);
                                index=index+4;
                        else if (GPGRS_datalen[i]==3)
                                 range_error[i]=(convertdata(GPS_buffer[index])+convertdata(GPS_buffer[index+2])*0.1);
                                 index=index+3;
                   squre_error=squre_error+range_error[i]*range_error[i];
       sse_error=sqrt(squre_error/(comma_number-4));
              squre_integer=(int)sse_error;
           if(squre_integer>9)
            squre_integer_high=squre_integer/10;
                squre_integer_low=squre_integer%10;
                display_square_error[0]=squre_integer_high|0x30;
           else
                squre_integer_low=squre_integer;
                display_square_error[0]=0x20;
       squre_error_yushu=sse_error-squre_integer;
       squre_temp=squre_error_yushu*1000;
       squre_decimal_inte1=squre_temp/100;
       squre_decimal_yushu=squre_temp%100;
       squre_decimal_inte2=squre_decimal_yushu/10;
       squre_decimal_inte3=squre_decimal_yushu%10;
       display_square_error[1]=squre_integer_low|0x30;
       display_square_error[2]='.';
           display_square_error[3]=squre_decimal_inte1|0x30;
       display_square_error[4]=squre_decimal_inte2|0x30;
       display_square_error[5]=squre_decimal_inte3|0x30;
       sv_status(comma_number,sse_error);
                        P1=0xfd;;
    else
void main(void)
        unsigned char   i;
        //unsigned char j,k;
        //unsigned char temp;
    serial_init();
    pps_init();
    delay();
         delay();
         delay();
     delay();
         delay();
         delay();
     write_comm(0x30,0);
         delay();
          delay();
     write_comm(0x30,0);
         delay();
     delay();
         delay();
         write_comm(0x0C,0);
         delay();
         delay();
         write_comm(0x01,0);
     delay();
          delay();
          delay();
          delay();
          delay();
      write_comm(0x06,0);
          delay();
          delay();
    EA = 1;
                P1=0xf8;
                                                        posdata_shu.val=0;
for(i=0;i<12;i++)
GPGRS_datalen[i]=0;
for(i=0;i<5;i++)
display_square_error[i]=0;
   while(1)
                 gps_data_convert();
                  if (posdata_shu.val==1)
                            P1=0xf8;
                      for(i=0;i<posdata_shu.off;i++)
               {        TI=0;
                             SBUF=*(posdata_shu.buf+i);
                                        *(posdata_shu.buf+i)=0;
                                 while(TI==0);
                                        TI=0;
                           posdata_shu.val=0;
                        posdata_shu.off=0;
                        LCD_ShowString(0,4,display_square_error,6);
                        LCD_ShowString(0,7,"米",2);
                        if(sv_status_flag==0xaa)
                         LCD_ShowString(1,5,"无故障",6);
                        else if(sv_status_flag==0x55)
              LCD_ShowString(1,5,"有故障",6);
                         for(i=0;i<5;i++)
                                           comma_number=0;
           for(i=0;i<12;i++)
           GPGRS_datalen[i]=0;
                LCD_ShowString(0,0,"伪距SSE:",8);
                 LCD_ShowString(1,0,"监测结果:",9);
//header.h
void serial_init()
{SCON  = 0x50;
TMOD |= 0x20;
TH1 = TL1 = 0XFD;
TR1   = 1;
PS = 1 ;
ES = 1;
PCON = 0x00; }
void pps_init()
{IT1 = 1;
EX1 = 1; }
typedef struct
                unsigned char check;
                unsigned char off;
                unsigned char val;
                unsigned char ful;
                unsigned char buf[80];
}GPS_DATA_SH;
mmbs 发表于 2013-5-16 22:18 | 显示全部楼层
看着是很庞大的工程的。
airwill 发表于 2013-5-17 06:57 | 显示全部楼层
其实也不是很困难.
C 语言是直接可以用的, 就是硬件相关的定时器, IO口等寄存器操作要移植.
jlass 发表于 2013-5-17 09:03 | 显示全部楼层
就这点代码量,估计3楼的大神一个小时就可以搞定了
 楼主| ahscchjch 发表于 2013-5-17 10:12 | 显示全部楼层
其实也不是很困难.
C 语言是直接可以用的, 就是硬件相关的定时器, IO口等寄存器操作要移植. ...
大神 帮帮忙 msp430才学没多久 io口和51的区别很大 还有用到了串口通信 msp430的和51的区别就更大了
 楼主| ahscchjch 发表于 2013-5-17 11:21 | 显示全部楼层
其实也不是很困难.
51的结构体移植到msp430也总报错啊
airwill 发表于 2013-5-17 11:48 | 显示全部楼层
一个小时就可以搞定, 那也看得太容易了些.
对于两个内核都熟悉的人来说, 应该不是太麻烦的工作.
51的结构体移植, 你的程序里好象没有看到结构体.
这也有可能是编译器的问题, 比如匿名问题.
用标准的结构体定义就不会存在编译器之间的差异.
 楼主| ahscchjch 发表于 2013-5-17 12:11 | 显示全部楼层
[quote][/quote]
a1339542929 发表于 2013-5-17 12:12 | 显示全部楼层
楼主搞好的移植贴一下,让我也欣赏一下,我也是最近需要了解msp430的
 楼主| ahscchjch 发表于 2013-5-17 12:25 | 显示全部楼层
怕是有的搞了
yang_2006 发表于 2013-5-17 15:48 | 显示全部楼层
毕设就只做软件,没硬件电路。
怎么知道你的外设用的那些端口。
 楼主| ahscchjch 发表于 2013-5-17 16:30 | 显示全部楼层
毕设就只做软件,没硬件电路。
怎么知道你的外设用的那些端口。
用的msp430的最小系统开发板  lcd12864接口是P2数据接口 RS P63 WR P64 EN P65  串口0 UTXD0 P34  URXD0 P35
 楼主| ahscchjch 发表于 2013-5-17 16:31 | 显示全部楼层
dwh000 发表于 2013-5-17 16:29
不难..
大神 给改改呗
zqjqq88 发表于 2013-5-17 16:52 | 显示全部楼层
纯属体力活,估计没几个人愿意帮你改!
mtlsh168 发表于 2013-5-17 17:55 | 显示全部楼层
唉 只能叹息现在的学生啥都没学会就又毕业了,
 楼主| ahscchjch 发表于 2013-5-17 18:24 | 显示全部楼层
亲 msp430的本科基本都是不学的
程序包子 发表于 2013-5-23 22:28 | 显示全部楼层
现在的学生啊,本科不学,自己要学啊,我自己就是学51又去学arm的,然后就去把以前的51程序移植到arm上,我说的arm是指arm0以及m3
新塘的mo516llan
和stm32
1988020566 发表于 2013-5-24 00:34 | 显示全部楼层
程序好凌乱
1988020566 发表于 2013-5-24 00:35 | 显示全部楼层
建议使用宏定义来写。
sign2012 发表于 2013-10-18 23:35 | 显示全部楼层
这个要用到GPS模块吗?具体有什么功能呢?楼主
