IAR for stm32 6.4 固件库V3.5
工程配置完工程后提示警告如下图:
配置错误
错误信息如下:
Sat May 18, 2013 13:22:27: The custom SFR file 'D:\IAR Systems\Embedded Workbench 6.4\arm\CONFIG\debugger\ST\iostm32f10xxB.ddf' contains a modification of the factory SFR 'SETPEND1.SETPEND45'. This
SFR cannot be found in the used factory SFR file 'D:\IAR Systems\Embedded Workbench 6.4\arm\CONFIG\debugger\ST\iostm32f10xxB.ddf' and the definition will be ignored.
Sat May 18, 2013 13:22:27: The custom SFR file 'D:\IAR Systems\Embedded Workbench 6.4\arm\CONFIG\debugger\ST\iostm32f10xxB.ddf' contains a modification of the factory SFR 'SETPEND1.SETPEND49'. This
Sat May 18, 2013 13:22:27: The custom SFR file 'D:\IAR Systems\Embedded Workbench 6.4\arm\CONFIG\debugger\ST\iostm32f10xxB.ddf' contains a modification of the factory SFR 'SETPEND1.SETPEND50'. This
请问题我这是哪出了问题呀?
