PWM-chopper 谁用过?
1881|0
 楼主| meishizhaoshi 发表于 2013-5-26 10:57 | 显示全部楼层 |阅读模式
**中讲到:
The PWM-chopper submodule allows a high-frequency carrier signal to modulate the PWM waveform
generated by the action-qualifier and dead-band submodules. This capability is important if you need
pulse transformer-based gate drivers to control the power switching elements.
