大神 帮帮忙忙啊看一下c程序怎么让它显示多个字?60个字。
2065|1
 楼主| 泗一起 发表于 2013-6-1 00:29 | 显示全部楼层 |阅读模式
#include <reg51.h>
#include <intrins.h>
#define  DATAOUT P2    //P2 use as data,  you can change
#define  SPEED  13
void ymove(char dir,unsigned char *ptr,char speed);
void xmove(char dir,unsigned char *ptr,char n,char speed);
void delay(unsigned int a);
void display();
void displaytime(char time);
void init164();
sbit  ADATA= DATAOUT^0;
sbit  ASCK=  DATAOUT^1;
sbit  LATCH= DATAOUT^2;
sbit  BDATA= DATAOUT^3;
sbit  BCLK=  DATAOUT^4;
code unsigned char xin[64]={
0x00,0x00,0x00,0x04,0x0FF,0x0FE,0x04,0x40, //西
0x04,0x40,0x04,0x44,0x7F,0x0FE,0x44,0x44,
0x44,0x44,0x44,0x44,0x44,0x44,0x48,0x34,
0x50,0x04,0x40,0x04,0x7F,0x0FC,0x40,0x04,
0x02,0x00,0x01,0x00,0x7F,0xFE,0x40,0x02,
0x82,0x04,0x02,0x00,0x02,0x04,0xFF,0xFE,
0x04,0x20,0x08,0x20,0x18,0x20,0x06,0x40,
0x01,0x80,0x02,0x40,0x0C,0x30,0x30,0x10};
code unsigned char zhong[32]={
0x02,0x00,0x01,0x00,0x7F,0xFE,0x40,0x02,//安
code unsigned char guo[32]={
        0x00,0x04,0x7F,0xFE,0x40,0x24,0x5F,0xF4,  //国
      0x41,0x04,0x41,0x04,0x41,0x44,0x4F,0xE4,
      0x41,0x04,0x41,0x44,0x41,0x24,0x41,0x04,
      0x5F,0xF4,0x40,0x04,0x7F,0xFC,0x40,0x04};
code unsigned char dui[32]={
        0x7C,0x40,0x44,0x40,0x48,0x40,0x48,0x40,  //队
      0x50,0x40,0x48,0x40,0x48,0x40,0x44,0xA0,
      0x44,0xA0,0x44,0xA0,0x69,0x10,0x51,0x10,
      0x42,0x08,0x44,0x06,0x48,0x04,0x00,0x00};
code unsigned char jia[32]={
        0x10,0x00,0x10,0x00,0x10,0x04,0x12,0x7E,  //加
      0xFF,0x44,0x12,0x44,0x12,0x44,0x12,0x44,
      0x12,0x44,0x22,0x44,0x22,0x44,0x22,0x44,
      0x22,0x44,0x4A,0x7C,0x84,0x44,0x00,0x00};
code unsigned char you[32]={
        0x00,0x40,0x40,0x40,0x30,0x40,0x10,0x44,  //油
      0x87,0xFE,0x64,0x44,0x24,0x44,0x0C,0x44,
      0x14,0x44,0x27,0xFC,0xE4,0x44,0x24,0x44,
      0x24,0x44,0x24,0x44,0x27,0xFC,0x24,0x04 };
code unsigned char gth[32]={
        0x00,0x00,0x01,0x80,0x03,0xC0,0x03,0xC0,    //!
      0x03,0xC0,0x03,0xC0,0x03,0xC0,0x01,0x80,
      0x01,0x80,0x01,0x80,0x00,0x00,0x01,0x80,
      0x03,0xC0,0x01,0x80,0x00,0x00,0x00,0x00};
unsigned char idata buffer[64];
void main(void)
        unsigned char i;
        init164();
        while(1)
                for(i=0;i<64;i++)
                        buffer=xin;
                displaytime(1);
                xmove(1,zhong,3,SPEED);
                displaytime(1);
                ymove(1,0,SPEED);
                ymove(1,jia,SPEED);
                ymove(1,you,SPEED);
                ymove(1,0,SPEED);
                xmove(0,jia,3,SPEED);
                ymove(0,gth,SPEED);
                ymove(0,0,SPEED);
                xmove(1,xin,1,SPEED);
/*************  子函数   ******************/
        while(a--);
void display()
        unsigned char hang,ib,k,tmp;
    DATAOUT= 0x0;
        BDATA = 0;
        for(hang=0;hang<16;hang++)
                ASCK =0;
                LATCH=0;
                BCLK =0;
                for(ib=0;ib<2;ib++)
                        tmp = buffer[hang*2+ib];
                        for(k=0;k<8;k++)
                                tmp <<=1;
                                ASCK  =0;
                                ADATA =CY;
                                ASCK  =1;
                DATAOUT|=0x14;
                //LATCH=1;
                //BCLK=1;
                BDATA=1;
        delay(64);
        ASCK =0;
        ASCK =1;
        unsigned char i;
        while(time--)
                i=130;
                while(i--)
                         display();
void init164()
        char i;
        BDATA=1;
        for(i=0;i<16;i++)
                BCLK =0;
                BCLK =1;
{      /*       方向                    n是要移动的汉字个数        移动速度*/
        unsigned char  i=0,  ib=0;
        unsigned int   tmp=0, speedm=0;
        unsigned char  buffer2[16];         //半个汉字的缓存
        n*=2;     //左半字和右半字,所以要x2
        for(i=0;i<16;i++)   //清零
                buffer2=0;
        if(dir == 1)
/****     向左移动    ****/
                for(n;n>0;n--)
                        if(ptr != 0)
                                tmp = n%2;        //判断是左半字还是右半字
                                for(i=0;i<16;i++)
                                        buffer2=ptr[i*2+tmp];
                                if(tmp)                //tmp为1时,将地址指向下一个汉字
                                        ptr+=32;
                        for(tmp=8;tmp>0;tmp--)  //要移动8列
                                ib=0;
                                for(i=0;i<16;i++)
                                {                //要移16行,共16个字节
                                        buffer[ib] <<=1; //移第一个半字
                                        if(buffer[ib+1] & 0x80)
                                                buffer[ib]++;
                                        ib++;
                                        buffer[ib]<<=1;                //移后半字
                                        if(buffer2 & 0x80)
                                                buffer[ib]++;
                                        ib++;
                                        buffer2<<=1;                //缓冲左半字向左移一位
                                speedm=speed;        //更新点阵
                                while(speedm--)
                                        display();
        else
   /******  向右移动   ******/
                for(n;n>0;n--)
                        if(ptr != 0)
                                tmp = (n+1) % 2  ;        //判断左半字还是右半字
                                for(i=0;i<16;i++)
                                if(tmp == 0)                //tmp为0时,将地址指向下一个汉字
                                        ptr+=32;
                                ib=0;
                                for(i=0;i<16;i++)
                                {                //要移16行,共16个字节
                                        buffer[ib+1] >>= 1;             //移右半字
                                        if(buffer[ib] & 0x01)
                                                buffer[ib+1] |=0x80 ;
                                        buffer[ib] >>= 1;            //移左半字
                                        if(buffer2 & 0x01)
                                                buffer[ib] |= 0x80;
                                        ib+=2;
                                        buffer2 >>=1;                //下个汉字的右半字向右移一位
                                speedm=speed;
                                while(speedm--)  //更新点阵
                                        display();
void ymove(char dir,unsigned char *ptr, char speed)
{                   //dir=1上移动,dir=0为下移动
        char i=0, j=0, ib=0;
        if(dir==0)
   /****  向下移  ****/
                ib=31;
                for(i=16;i>0;i--)   //下移16行
                        for(j=29;j>-1;j--)
                                buffer[j+2]=buffer[j];        //将上一行的内容复制到下一行
                        if(ptr==0)
                        {                                //移空时,buffer的首行用0移入
                                buffer[0]=0;
                                buffer[1]=0;
                        else
                        {                                //否则,处理buffer的首行元素
                            buffer[1]=ptr[ib];
                                buffer[0]=ptr[ib-1];
                                ib=ib-2;
                        speedm=speed;
                                display();
/****** 向上移 *******/
        else
                ib=0;          //数组元素序号
                for(i=0;i<16;i++)    //上移16行
                        for(j=0;j<30;j++)           //将下一行的内容复制到上一行
                                buffer[j]=buffer[j+2];
                        if(ptr==0)        //移入为空,buffer的末行用0移入
                                buffer[30]=0;
                                buffer[31]=0;
                        else
                        {                        //否则,处理buffer的末行元素
                                buffer[30]=ptr[ib];
                                buffer[31]=ptr[ib+1];
                                ib=ib+2;
                        while(speedm--)
                                display();
NE5532 发表于 2013-6-1 08:10 | 显示全部楼层
1.在什么东西上显示?
2.现在程序问题是什么?
