PSOC3到底可以不可以用idata定义数据 ?
1389|1
 楼主| yangniaopen 发表于 2013-6-5 17:51 | 显示全部楼层 |阅读模式
如题,我用idata 定义了一个变量后 用sbit定义了几个位变量,但是编译的时候老出现错误,提示变量地址有误
global_EXT bdata uint8 Flag_Reg1;             //global system status registor1
global_EXT sbit Com_Flag              = Flag_Reg1^0;    //flag is ON when VDD_CAN_Sensor is detected,it is set in ISR function
global_EXT sbit Current_Sampling_Flag = Flag_Reg1^1;    //flag is ON when 12 cells voltage sampling is finished
global_EXT sbit Volatge_Sampling_Flag = Flag_Reg1^2;    //flag is ON when 12 cells voltage sampling is finished
global_EXT sbit VDD_CAN_Flag          = Flag_Reg1^4;    //flag is ON when Extenal power is ON
这是编译器提示:'Flag_Reg1': invalid base address
到底问题在哪里呢?
kk5290122 发表于 2013-6-6 08:02 | 显示全部楼层
PSOC3里面的位寻址是比51里面的寻址范围更宽的……
