初学pic电机控制
2465|1
 楼主| woxuepic 发表于 2013-6-8 09:49 | 显示全部楼层 |阅读模式
最近刚学pic电机控制,用的是dsPIC30f2010,采用全桥电路控制三相无刷电机,参考了微芯的程序,把程序最简单话了,但是没有PWM输出,不知道为什么,代码如下:
#include "p30F2010.h"
#define FCY  10000000                        // xtal = 5.0Mhz; PLLx8
#define MILLISEC FCY/10000                        // 1 mSec delay constant
#define FPWM 39000
#define POLEPAIRS        5                // number of pole pairs of the motor
#define INDEX        1                        // Hall sensor position index
void InitMCPWM(void);
int main(void)
        LATE = 0x0000;
        TRISE = 0xFFC0;                // PWMs are outputs
        CNEN1 = 0x00E0;                // CN5,6 and 7 enabled
        CNPU1 = 0x00E0;                // enable internal pullups
        IFS0bits.CNIF = 0;        // clear CNIF
        IEC0bits.CNIE = 1;        // enable CN interrupt
        InitMCPWM();
        while(1)
             PWMCON1 = 0x0777;                                        // enable PWM outputs
                  OVDCON =0x0210;        //这里我把程序简化了,想直接看看有没有PWM输出
        DelayNmSec(500);
        }        // end of while (1)
}        // end of main
        PTPER = FCY/FPWM - 1;                // set the pwm period register
        PWMCON1 = 0x0700;                        // disable PWMs
        OVDCON = 0x0000;                        // allow control using OVD register
        PDC1 = 200;                                        // init PWM DC 1, 2 and 3 to 100
        PDC2 = 200;
        PDC3 = 200;
        SEVTCMP = PTPER;                // set ADC to trigeer at ...
        PWMCON2 = 0x0F00;                // 16 PWM values
        PTCON = 0x8000;                        // start PWM however output ...
                                                        // is enabled by OVDCON which is OFF
求大神么指教啊
触觉的爱 发表于 2013-6-8 13:46 | 显示全部楼层
时钟部分的设置没看到呀
