wangxm86 发表于 2013-6-9 10:24
DRC一下,看看是怎么说的
DRC结果
Processing Rule : Clearance Constraint (Gap=0.25mm) (On the board ),(On the board )
Violation between Track (17.7612mm,3.1516mm)(17.7612mm,3.6596mm) BottomLayer and Pad U2-13(17.7612mm,3.4056mm) BottomLayer
这什么意思啊?U2-13就是图中元件的13脚
