stm32f103 ADC 间断模式,如何一次性读取8组ADC数值
3181|4
 楼主| yangjizhufei 发表于 2013-6-17 11:09 | 显示全部楼层 |阅读模式
// 工作模式配置 ----------------------------------------------------------------
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 8;
ADC_Init(ADC1, &ADC_InitStructure);
// 采样顺序及时间配置 ----------------------------------------------------------
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 2, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 3, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 4, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 5, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 6, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 7, ADC_SampleTime_71Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 8, ADC_SampleTime_71Cycles5);
//间断模式配置------------------------------------------------------------------
ADC_DiscModeCmd(ADC1);
ADC_DiscModeChannelCountConfig(ADC1,1);
//ADC_DMA_Set(ADC1);                         // 开启 DMA
ADC_TempSensorVrefintCmd();                  // 使能温度传感器和 Vrefint通道
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);      // 开转换完成中断
ADC_Cmd_Set(ADC1);                           // 启动 ADC
ADC_ResetCalibration(ADC1);                  // 初始化校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);                  // 校准
while(ADC_GetCalibrationStatus(ADC1));
配置如下,但是不知道如果读取????
 楼主| yangjizhufei 发表于 2013-6-17 11:27 | 显示全部楼层
这句我改成了ADC_DiscModeChannelCountConfig(ADC1,8);
IJK 发表于 2013-6-17 12:11 | 显示全部楼层
ADC工作模式需要明确:ScanConvMode = DISABLE,还是 ScanConvMode = ENABLE ?
 楼主| yangjizhufei 发表于 2013-6-17 13:55 | 显示全部楼层
ScanConvMode = ENABLE   ,
 楼主| yangjizhufei 发表于 2013-6-17 14:22 | 显示全部楼层
