DC-100MHz wideband isolation amplifier
2270|0
 楼主| lidajun 发表于 2007-9-13 11:14 | 显示全部楼层 |阅读模式
We can provide DC-100MHz wideband isolation amplifier module. The specifications are shown below:
Bandwidth: DC-100MHz
Maximum Working Insulation Voltage: 1414Vpeak
Input-Output Momentary-Withstand Voltage (t=1min): 5000Vrms
Highest Allowable Overvoltage (Transient Overvoltage, t = 10 sec): 8000Vpeak
Input-Output Resistance: >2 G ohm
Gain:    Can be set from x1 to x10
Gain Nonlinearity: <1%
Maximum output voltage: ±1.5V
Output Noise: <2mVrms
Power Supply: ±5V x2
Operating Temperature:    -10°C to+70°C
Dimensions: 90mmx53mmx10mm
http://www.cheele.cn/data/skins/chinese024/eng_01.htm
