天气不好我也要晒 晒板,大家多指教
2922|5
 楼主| chaser2008 发表于 2008-6-23 10:05 | 显示全部楼层 |阅读模式
IO, TI, board, vi, TE
我这是一块连接蒸发传感器的电路,其中blue,green,red,white为传感器的输出和输入,在DRC校验时报如下错误,请指点帮忙改正,对各位大虾致谢!<br />Protel&nbsp;Design&nbsp;System&nbsp;Design&nbsp;Rule&nbsp;Check<br />PCB&nbsp;File&nbsp;:&nbsp;PCB1.PCB<br />Date&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;23-Jun-2008<br />Time&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;10:01:16<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Short-Circuit&nbsp;Constraint&nbsp;(Allowed=Not&nbsp;Allowed)&nbsp;(On&nbsp;the&nbsp;board&nbsp;),(On&nbsp;the&nbsp;board&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Broken-Net&nbsp;Constraint&nbsp;(&nbsp;(On&nbsp;the&nbsp;board&nbsp;)&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Clearance&nbsp;Constraint&nbsp;(Gap=10mil)&nbsp;(On&nbsp;the&nbsp;board&nbsp;),(On&nbsp;the&nbsp;board&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Width&nbsp;Constraint&nbsp;(Min=10mil)&nbsp;(Max=10mil)&nbsp;(Prefered=10mil)&nbsp;(On&nbsp;the&nbsp;board&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Hole&nbsp;Size&nbsp;Constraint&nbsp;(Min=1mil)&nbsp;(Max=100mil)&nbsp;(On&nbsp;the&nbsp;board&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br /><br />Violations&nbsp;Detected&nbsp;:&nbsp;0<br />Time&nbsp;Elapsed&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;00:00:01
xwj 发表于 2008-6-23 10:09 | 显示全部楼层
该打PP
自动布线?<br />不会对齐到网格?<br />不会修改线径?<br />地平面完整性、铺铜就更别说了
 楼主| chaser2008 发表于 2008-6-23 10:13 | 显示全部楼层
我也很郁闷
没有做过,也没有人教学,硬着头皮自己自学做的,刚出来的物理本科生
王紫豪 发表于 2008-6-23 12:38 | 显示全部楼层
报错了吗?我咋没看出来?即使自己学也要严格要求自己啊
ps&nbsp;我也是自己学的
oufuqiang 发表于 2008-6-25 21:20 | 显示全部楼层
Violations Detected : 0
汗……
善解人意 发表于 2008-6-29 15:03 | 显示全部楼层
天气不好我也要晒  晒板,大家多指教
元件摆的不整齐,先步好骤再步线.要养成好的习惯
